SNMP Polling
emejias23
Community Member
I'm not sure if this is the correct place to post. I had snmp link state up down set on my 3750, but with the number of users disconnecting their laptops, it was generating a huge amount of alarms. So we decided it was best to disable. After disabling we are still getting a number of errors, though and generating the following:
SNMP poll failure (NOSUCHNAME) for poll Buffer Failures/Basic_bufferFail and target <ip_address>.
I did sh snmp and see the following errors.
2284 No such name errors
What is this attributed to? And what's the best solution?
JohnTylerPearce
Level 11
Level 11
Emmanuel,
I've honestly never seen this before, but it almost looks like the SNMP Buffer is full, if there is such a thing. I see this is on a 3750, is this stacked?
Ah yes, I forgot to mention that this is stacked.
