SNMP trap send every 30 seconds
I have a snmp trap sent every 30 seconds from one of my cisco switches (a stack of 3750 to be precise):
ccStatusMemberStatusChange
Do you know what it is and why it is sent continuously??
Thank you for your answers.
Flo
acampbell
Flo,
If you are receiving this message constantly from your
switch stack you need to investigate further.
Sounds like a switch is not connecting properly
ccStatusMemberStatusChange ccMemberOperStatus = active(1)
Cluster member active, messages received by command switch
Informational
Network Element
None
ccStatusMemberStatusChange ccMemberOperStatus = inactive(2)
Cluster member inactive, messaged failed to be received by command switch
Informational
Network Element
None
Use the guide at this link link
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_55_se/configuration/guide/swstack.html#wp1284240
Or find the guide for your version of IOS
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_installation_and_configuration_guides_list.html
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
