09-23-2019 01:11 AM - edited 09-23-2019 01:50 AM
hi,
currently only CPU and memory are being monitored in solarwinds for our cisco switches: 3850, 9300, N5K, ME3600x, etc.
i would need to add hardware monitoring for the hot swap modules, i.e. fans and power supply.
is there a specific SNMP trap that i need to configure/enable?
09-23-2019 06:57 AM
Hi John,
As far as I know, when you add any of these devices to SW, it should by default monitor, CPU, memory, fans, PSUs, etc.. and you should be able to see that in the summary page for that device. If not you can always click on the specific device and than click on "edit node" to see what is being monitored. This is all done in NPM.
09-23-2019 06:52 PM - edited 09-23-2019 06:57 PM
hi reza,
when i edit a SW node, i saw we're using the default 'use global setting' under hardware health polling option for cisco MIB.
it seem it's just the CPU, memory, temperature MIB are being monitored.
i'll ask our SW admin to create a custom MIB to help monitor these modules in case of a failure.
i've already configured SNMPv3 and added/polled the switch in our SW.
is there any additional SNMP config or trap i need to add on the cisco switch? or is this just a tweak (MIB) in SW like i mentioned?
09-23-2019 07:47 PM
Hi John,
The other place to look is under "manage resources" where the "Hardware Health Sensors" icon should be checked.
