SNMPV3 Configuration
uni1389
Hello Team am trying to configure SNMPv3 with MD5 /SHA , but with MD5 it is working but SHA is not working . Snapshot are also attached for reference from SNMP Tester.
Cisco IOS XE Software, Version 17.03.04a
Cisco IOS Software [Amsterdam], Virtual XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.3.4a, RELEASE
snmp-server user CheckMK01 CheckMK v3 auth md5 Cisco123456 priv des Cisco123456
snmp-server user CheckMK CheckMK v3 auth sha Cisco123456 priv aes 256 Cisco123456
CSR-SiteA#show snmp user
User name: CheckMK
Engine ID: 8000000903005000002D0000
storage-type: nonvolatile active
Authentication Protocol: SHA
Privacy Protocol: AES256
Group-name: CheckMK
User name: CheckMK01
Authentication Protocol: MD5
Privacy Protocol: DES
Group-name: CheckMK
CSR-SiteA#
uni1389
snmp-server user CheckMK CheckMK v3 auth sha Cisco123456 priv aes 256 Cisco123456 <<- try priv des not aes 256
Aes 256 need secuirty license I think
MHM
Jens Albrecht
Hello @uni1389,
I just tested this with IOS-XE 17.3.8a and an active ax license.
The problems are due to AES-256 and not to SHA. The ax license includes the security license and AES-256 is still not working. I also did a quick test on another routing platform with the same result. So it has nothing to do with the license.
You can use SHA if you combine it with AES-128 encryption. This works reliably on both platforms I tested.
Well, and really never use DES. That's broken and simply means that you do not use encryption.
So using this command should work:
snmp-server user CheckMK CheckMK v3 auth sha Cisco123456 priv aes 128 Cisco123456
HTH!
Just completed some additional tests on the second platform which is a Cat8000v running IOS-XE 17.16.1a.
This confirmed that the problems are due to the combination of SHA with AES-256.
These newer software versions support SHA-2 which works just fine with AES-256.
So on the Cat8000v the following users do work:
snmp-server user SNMP3U4 SNMP3G v3 auth sha-2 256 MyS3cureAuth priv aes 256 MyS3curePriv
snmp-server user SNMP3U5 SNMP3G v3 auth sha-2 512 MyS3cureAuth priv aes 256 MyS3curePriv
However, the combination of SHA with AES-256 does not work on this platform either.
SHA-2 support for SNMPv3 was introduced with IOS-XE 17.10.1a.
If you are running any older version that only supports SHA you are limited to AES-128 encryption.
HTH!
