SNMPv3 Encryption Issues on Cisco Catalyst 3850 (IOS 16.12.12) - Auth
immolation
Community Member
Hi Cisco Community,
I’ve been troubleshooting SNMPv3 on a Catalyst 3850-48U-E (IOS 16.12.12) for Zabbix 7.0.1 monitoring, aiming for SHA auth and AES-256 encryption. Auth-only works perfectly, but enabling privacy (encryption) results in timeouts. Has anyone seen this behavior on a 3850-48U-E and found a solution?
Setup and Config Attempts
  • Switch Details: Catalyst 3850 (WS-C3850-48U), IOS 16.12.12 (CAT3K_CAA-UNIVERSALK9, BUNDLE mode), VLAN 100 with DHCP IP 192.168.1.10, standalone (renumbered from Switch 2 to 1).
  • SNMPv3 with Encryption:
    snmp-server group MonitorGroup v3 priv read v1default
    snmp-server user MonitorUser MonitorGroup v3 auth sha AuthPass123 priv aes 256 PrivPass456
    snmp-server host 192.168.1.100 version 3 priv MonitorUser
    snmp-server enable traps
  • Test: snmpwalk -v3 -l authPriv -u MonitorUser -a SHA -A AuthPass123 -x AES256 -X PrivPass456 192.168.1.10—times out.
  • Debug: debug snmp packets shows packets arriving on VLAN 100, but returns usmStats.4.0 = 3 (Unknown Engine ID). Tried setting snmp-server engineID local 8000000903007001B595EC00—no change.
  • ACL Attempt: Added an access list to restrict SNMP:
    ip access-list extended SNMP-ALLOW
     permit udp host 192.168.1.100 host 192.168.1.10 eq 161
    interface vlan 100
     ip access-group SNMP-ALLOW in
    Blocked all traffic (including SSH), so removed it with no ip access-group SNMP-ALLOW in—traffic’s open now.
  • Working Config (Auth-Only):
    snmp-server group MonitorGroup v3 auth read v1default
  • Test: snmpwalk -v3 -l authNoPriv -u MonitorUser -a SHA -A AuthPass123 192.168.1.10—works fine, polls with Zabbix (Cisco IOS by SNMP template).
  • v1/v2c: Disabled with no snmp-server community public RO—v2c tests timeout, confirming it’s off.
The Problem
  • Auth-only (SHA-1) works, but AES-256 privacy fails consistently—timeout, no response beyond debug’s Engine ID error.
  • v2c worked before disabling, and ping to 192.168.1.10 is ~1.5ms, so UDP 161 isn’t blocked.
  • No ACLs now—ruled out filtering.
Key Details
  • IOS Version: 16.12.12
  • Model: WS-C3850-48U
  • Engine ID: 8000000903007001B595EC00 (from show snmp user)
Questions
  • Has anyone hit this SNMPv3 privacy issue on a Catalyst 3850 with IOS 16.12.x?
  • Could this be an IOS bug with AES-256, or is there a config step I’m missing?
  • Any workarounds besides auth-only?
Thanks for any pointers!
Mark Elsen
     - What happens when you try with AES-128  (instead of 256) ?
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
AES-128 works.
   -Probably a bug on the Cisco device ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
