Software to measure throughput in LAN
Hi i need some software for Windows envoriment that can meansure a throghput between two lan endpoints.
I've tried Qcheck, but it wont run in 64bit or send data packets lager than 1mb
Can you recommend some software for this purpose?
Best regards
Steffen.
IAN WHITMORE
Level 4
Level 4
IAN WHITMORE
Level 4
Level 4
I think you should try iperf.
http://sourceforge.net/projects/iperf/
Ian
hobbe
Level 7
Level 7
This is not end to end but almost, it might be a interesting test tool to test a path.
the unsupported TTCP command in the switches.
have a look here!
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a0080094694.shtml
Good luck
