EIGRP from Vlan
ssweehinlew
Anyone can show me the example for configuring EIRGP from vlan of 2 switches? For example vlan 289, switch A (vlan ip: 192.168.10.2) and switch B (vlan ip: 192.168.10.3). Thanks.
mahmoodmkl
Level 7
Level 7
Assuming that there is a trunk or a layer 2 connection between the switches you can use the below commands.
switch(config)#routrer eigrp 10
switch(config-rotuer)#network 192.168.10.0
configure the same on both the switches.
If I have additional EIGRP neighbors, do i need to use the same network IP as them in order for them to communicate with each other?
for example:
switch#sh ip eigrp nei
H          Address          Interface
1          192.168.111.2    vlan 289
0          192.168.111.3    vlan 289
I didnt get wht you u mean.
For two eigrp devices to become neighbor they need to be on the same subnet or else they will not become neighbors.
