Software Update Problem
dlitteer
Community Member
I'm trying to make a backup of a production 2610 router, and would like to update the software on the spare router using TFTP server on a PC connected via a cross-over cable. IP addresses are set on both the router's ethernet 0/0 interface and the PC, however I can ping the router from the PC,but can't ping the PC from the router. Is there a command I'm missing, or just basic networking stuff I'm forgetting?
Jon Marshall
Could you just check that you do not have a firewall on your PC that could be blocking the pings from the router.
Jon
Jon Marshall
Jon
I agree with Jon that the most common cause of problems like this is a firewall running on the PC. If it is not a firewall issue then I would suggest checking the mask configured on the PC and make sure that it agrees with the mask on the router.
Rick
Rick
Good lord. That was it. Talk about overthinking yourself right out of a solution. Thanks for your help Jon.
