02-18-2019 02:41 PM - edited 03-08-2019 05:22 PM
Hello My question is if I can monitor with the SolarWinds software, industrial switches (IE2000, IE4000) I hope someone can help me.
Thank you
Solved! Go to Solution.
02-18-2019 02:47 PM
SolarWinds NPM is all SNMP based. So, it should not be an issue. If you don't see the proper model after the installation you can always ask their tech support or post a question on their forum (Thwack).
02-18-2019 02:47 PM
02-18-2019 02:51 PM
thank you :)
02-18-2019 02:56 PM
Good Luck!
SolarWinds communities are pretty good with knowledgeable people who answer questions.
