Solarwinds showing interfaces with receive errors and discards errors but switchports are clean
Tshi M
Level 5
Level 5
Leo Laohoo
Last clearing of "show interface" counters 08:19:50
In both interfaces, someone's cleaned out the counters.
Try "sh interface summary".
Yes, we cleared the counters every morning...the errors as reported by Solarwinds were seen intra day (i.e. after the counters were cleared).
sh int g1/27 sum
*: interface is up
IHQ: pkts in input hold queue     IQD: pkts dropped from input queue
OHQ: pkts in output hold queue    OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec)          RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec)          TXPS: tx rate (pkts/sec)
TRTL: throttle count
  Interface           IHQ   IQD  OHQ   OQD  RXBS RXPS  TXBS TXPS TRTL
* GigabitEthernet1/2    0     0    0     0     0    0  1000    1    0
NOTE:No separate counters are maintained for subinterfaces
     Hence Details of subinterface are not shown
sh int g1/35 sum
*: interface is up
* GigabitEthernet1/3    0     0    0     0  2000    3  5000    8    0
Attached you will find the output of sh counters g1/27 & g1/35
come to think of it. Solarwinds is not reporting on the switch level but the server level. So, it might be a problem with the server and not on the switch.
