Solarwinds Transmit Discards for 3750 Switch
Eric Rickard
My Solarwinds product is showing a high volume of transmit discards on several interfaces of my Cisco 3750E switch.  Can anyone give me a suggestion on what could be causing this and how to resolve it?
My Switch info:
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE5, RELEASE SOFTWARE (fc1)
License Level: ipservices
License Type: Permanent
Next reload license Level: ipservices
cisco WS-C3750X-48 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Last reset from power-on
7 Virtual Ethernet interfaces
1 FastEthernet interface
104 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
512K bytes of flash-simulated non-volatile configuration memory.
Motherboard assembly number     : 73-12552-10
Model revision number           : A0
Motherboard revision number     : C0
Model number                    : WS-C3750X-48T-S
Daughterboard assembly number   : 800-32727-03
Top Assembly Part Number        : 800-31326-08
Top Assembly Revision Number    : D0
Version ID                      : V05
Hardware Board Revision Number  : 0x05
Switch Ports Model              SW Version            SW Image
*    1 54    WS-C3750X-48       12.2(55)SE5           C3750E-UNIVERSALK9-M
     2 54    WS-C3750X-48       12.2(55)SE5           C3750E-UNIVERSALK9-M
Solarwinds is showing:
High Errors & DiscardsToday
NODEINTERFACERECEIVE ERRORSRECEIVE DISCARDSTRANSMIT ERRORSTRANSMIT DISCARDS
CoreStack-1 Port-channel40 - Po40 0 errors 0 discards 0 errors 4,583,772 discards
CoreStack-1 GigabitEthernet2/0/14 · 0 errors 0 discards 0 errors 3,536,946 discards
CoreStack-1 GigabitEthernet2/0/16 · 0 errors 0 discards 0 errors 1,046,826 discards
CoreStack-1 GigabitEthernet1/0/11 · 0 errors 0 discards 0 errors 679,027 discards
CoreStack-1 Port-channel1 - Po1 0 errors 0 discards 0 errors 679,027 discards
CoreStack-1 Port-channel30 - Po30 0 errors 0 discards 0 errors 5,407 discards
CoreStack-1 GigabitEthernet2/0/1 ·0 errors 0 discards 0 errors 4,658 discards
Thank you.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Generally bursty traffic will cause it on any 2960/3560/3750 especially if QoS is enabled.
Buffer tuning, when QoS is enabled, can sometimes mitigate or eliminate.
On the 3560/3750 series, buffers are shared between 24 copper ports and for the uplink ports, so moving busy ports about might mitigate or eliminate drops too.
