[Solved] Fiber port problem on Catalyst 3750
adbemmaus
I am trying to configure a small network for NGO.
We have multiple Cisco ESW 520 that will be the link with fiber on a Catalyst 3750.
I have correctly configurated all ESW 520 with VLAN1 adress like 192.168.0.10 and netmask 255.255.240.0 .
I think i have correctly configurated the Catalyst 3750 with a VLAN1 address like 192.168.0.30 and netmask 255.255.240.0
But I have a problem, when we connecting all together, there's no fiber LED come on any switches to show connection or activity, and i can no ping the Catalyst 3750.
The VLAN1 is configurated for all fiber port on the ESW 520 and Catalyst 3750.
Here the show vlan command result :
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/1, Gi1/0/2, Gi1/0/3
                                                Gi1/0/4, Gi1/0/5, Gi1/0/6
                                                Gi1/0/7, Gi1/0/8, Gi1/0/9
                                                Gi1/0/10, Gi1/0/11, Gi1/0/12
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Remote SPAN VLANs
Primary Secondary Type              Ports
Thank for your help.
adbemmaus
Now i find one of my probleme, i connect the wrong fiber module connector to the Catalyst 3750, and this bad action disactivated the GigabitEthernet Port.
Now I try to find the command to activate the Port who are desactivated by the using of a wrong module.
I try to shuting down and restart interface with the command "configure terminal" but no change, the port where i use the wrong connector stay off with no status led.
If you have an idea of other tips to do.
OK
I make en Factory reset and all work fine.
