[SOLVED] Having big trouble with Catalyst ME 3400!
I have managed to reset to factory defaults a Catalyst ME 3400, but no matter what I did, I could not get it to respond to pinging.
CISCO#show run
Building configuration...
Current configuration : 3562 bytes
version 12.2
no service pad
hostname CISCO
boot-start-marker
boot-end-marker
no aaa new-model
system mtu routing 1998
ip subnet-zero
ip domain-name ahlat.com.tr
crypto pki trustpoint TP-self-signed-96207744
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-96207744
 revocation-check none
 rsakeypair TP-self-signed-96207744
crypto pki certificate chain TP-self-signed-96207744
 certificate self-signed 01
[redacted]
  quit
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
vlan dot1q tag native
vlan 2
 name VLAN_PCS
vlan 3
 name VLAN_WIFI
vlan 4
 name VLAN_VOIP
vlan 5
 name VLAN_CAMS
vlan 6
 name VLAN_A
vlan 7
 name VLAN_B
vlan 8
 name VLAN_C
vlan 9
 name VLAN_D
vlan 10
 name VLAN_E
vlan 11
 name VLAN_F
vlan 12
 name VLAN_G
vlan 13
 name VLAN_H
ip ssh time-out 60
ip ssh version 2
interface GigabitEthernet0/1
 switchport mode trunk
interface GigabitEthernet0/2
 switchport access vlan 3
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
 port-type nni
interface GigabitEthernet0/14
 port-type nni
interface GigabitEthernet0/15
 port-type nni
interface GigabitEthernet0/16
 port-type nni
interface Vlan1
 ip address 192.168.2.8 255.255.255.0
ip default-gateway 192.168.2.1
no ip http server
ip http secure-server
ip classless
control-plane
line con 0
 speed 115200
line vty 0 4
 login
line vty 5 15
 login
end
What am I missing? Please help.
"This new learning amazes me, Sir Bedevere. Explain again how sheep's bladders may be employed to prevent earthquakes." King Arthur
15 Replies 15
Thanks for the update. Glad that you were able to update the software and that now things are working. I wish that we have been able to identify the cause of the issue. But at this point I do not think it is possible.
Rick
