[SOLVED] Port forwarding issue from external IP to LAN
Piotr Pawlowski
Dear all,
First of all I need to explain, that I am quite new in in Cisco routers.
I have router 2911/k9 sec which is designated to be a edge router of my LAN.
I made some basic configuration (NAT) and till now everything works. Unfortunately I stuck with port forwarding.
From external IP attached to my router I need to forward several ports (two in this example) to servers located in LAN. I used 'ip nat inside source static' command , but only thing I get is following result from nmap scan:
666/tcp  filtered doom
3306/tcp filtered mysql
Below is full configuration of my router. Any help or tip will be helpful.
! Last configuration change at 08:22:51 PCTime Tue Oct 23 2012
version 15.2
service sequence-numbers
hostname Gdansk
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
clock timezone PCTime 1 0
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
no ipv6 cef
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip domain name mydomain.net
ip name-server 10.0.0.2
ip name-server 10.0.0.24
ip cef
crypto pki trustpoint TP-self-signed-1717998411
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1717998411
revocation-check none
rsakeypair TP-self-signed-1717998411
crypto pki certificate chain TP-self-signed-1717998411
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31373137 39393834 3131301E 170D3132 30383032 31333236
  31345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 37313739
  39383431 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B739 4575E476 1C271022 23258FA7 ABF85DB1 F376EC75 6A1CDDD9 BCCB9EBC
  FDCB44E7 1727CCD1 F65BFD45 AC8A90CF D68AE9AE 10765ED6 835825CE 3BEFB08B
  D133BEE0 183666E7 33C0344B 58E84E97 B1951597 D9396981 E8942A8A 2CC8722E
  59DE9B96 FF639EFF 605F9A2F 203E47DC B7634402 2DF1D7D3 21C4D1DF 82F32F3B
  A2690203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14FA462C 0F04FBEF 4CDFAFB6 019FCD3D 7270F6DC CA301D06
  03551D0E 04160414 FA462C0F 04FBEF4C DFAFB601 9FCD3D72 70F6DCCA 300D0609
  2A864886 F70D0101 05050003 818100AB 5F85219A ED4AD5D7 7550A993 D69E089B
  9D38D37E FBF6E84D F37076C4 DD360B74 9D60E18F 2C96F705 2DA89E62 40655BC5
  5D7CAFF6 C8C73BA2 BEFAB50B DE916D59 F7046ACD 4D4C5714 543DC7F4 0F2A5E4F
  F89CDE3D 2BC6DE6C 56F3AE07 DBAC1877 73FB7B92 5C42B812 1393D8E5 191F14C9
  FE813EA0 9186A172 297C64BB E90346
        quit
license udi pid CISCO2911/K9 sn FCZ163120Y4
file privilege 0
username gyadmin privilege 15 secret 5 $1$sNpI$djN.gxR08ssB5y4zhQtAA0
redundancy
ip ftp username backup
ip ftp password SecretPassword
ip ssh maxstartups 4
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$$ES_LAN$
ip address 10.0.0.1 255.255.254.0
ip access-group 101 in
ip access-group 101 out
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description "TASK"
ip address 213.192.65.74 255.255.255.252
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/2
description "Wit-Net"
ip address 193.107.215.133 255.255.255.224
duplex auto
speed auto
ip default-gateway 213.192.65.73
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip nat pool GoyellonNat 10.0.0.1 10.0.1.254 netmask 255.255.254.0
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip nat inside source list 199 interface GigabitEthernet0/2 overload
ip nat inside source static tcp 10.0.0.24 666 interface GigabitEthernet0/1 666
ip nat inside source static tcp 10.0.0.24 3306 interface GigabitEthernet0/1 3306
ip route 0.0.0.0 0.0.0.0 213.192.65.73
ip access-list extended inbound
permit ip any any
ip access-list extended outbound
permit ip any any
access-list 1 permit any
access-list 10 permit 195.2.255.11
access-list 10 permit any
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 10.0.0.0 0.0.1.255
access-list 100 permit tcp any eq www any
access-list 100 permit tcp any eq 443 any
access-list 101 permit ip any any
access-list 110 permit icmp any any echo
access-list 110 permit icmp any any echo-reply
access-list 110 permit icmp any any source-quench
access-list 110 permit icmp any any packet-too-big
access-list 110 permit icmp any any time-exceeded
access-list 110 deny   icmp any any
access-list 110 permit icmp any any unreachable
access-list 110 permit icmp any any port-unreachable
access-list 199 permit ip any any
control-plane
line con 0
password Password
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
From your translations table your static entries are in there:
Pro Inside global      Inside local       Outside local      Outside global
tcp 213.192.65.74:666  10.0.0.24:666      ---                ---
tcp 213.192.65.74:3306 10.0.0.24:3306     ---                ---
Is server 10.0.0.24 online and listening on TCP ports 666 and 3306?
It's not best practice to allow anything inbound on your outside interface
You might want to restrict inbound untrusted traffic by modifying ACL 101
6 Replies 6
Can you please provide the output for sh ip nat translation ?
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
Hi Muhammad
Thank you for you reply.
Below you can find the output of command show ip nat translation:
tcp 213.192.65.74:32981 10.0.1.12:32981   23.62.144.214:443  23.62.144.214:443
tcp 213.192.65.74:32988 10.0.1.12:32988   23.62.144.214:443  23.62.144.214:443
tcp 213.192.65.74:32989 10.0.1.12:32989   23.62.144.214:443  23.62.144.214:443
tcp 213.192.65.74:32990 10.0.1.12:32990   23.62.144.214:443  23.62.144.214:443
tcp 213.192.65.74:32991 10.0.1.12:32991   23.62.144.214:443  23.62.144.214:443
tcp 213.192.65.74:32992 10.0.1.12:32992   23.62.144.214:443  23.62.144.214:443
tcp 213.192.65.74:33386 10.0.1.12:33386   78.141.179.16:12350 78.141.179.16:12350
tcp 213.192.65.74:33796 10.0.1.12:33796   80.247.163.112:777 80.247.163.112:777
tcp 213.192.65.74:33852 10.0.1.12:33852   75.101.129.255:443 75.101.129.255:443
tcp 213.192.65.74:35325 10.0.1.12:35325   209.85.148.102:80  209.85.148.102:80
tcp 213.192.65.74:35538 10.0.1.12:35538   31.13.80.20:443    31.13.80.20:443
tcp 213.192.65.74:35576 10.0.1.12:35576   31.13.80.20:443    31.13.80.20:443
tcp 213.192.65.74:35577 10.0.1.12:35577   31.13.80.20:443    31.13.80.20:443
tcp 213.192.65.74:36943 10.0.1.12:36943   184.73.185.83:443  184.73.185.83:443
tcp 213.192.65.74:37359 10.0.1.12:37359   174.129.236.25:443 174.129.236.25:443
tcp 213.192.65.74:37981 10.0.1.12:37981   108.160.160.160:80 108.160.160.160:80
tcp 213.192.65.74:38024 10.0.1.12:38024   74.125.136.104:443 74.125.136.104:443
tcp 213.192.65.74:38460 10.0.1.12:38460   199.47.217.173:443 199.47.217.173:443
tcp 213.192.65.74:38770 10.0.1.12:38770   72.163.5.80:443    72.163.5.80:443
tcp 213.192.65.74:38978 10.0.1.12:38978   83.81.169.228:56975 83.81.169.228:56975
udp 213.192.65.74:40839 10.0.1.12:40839   46.44.144.140:49174 46.44.144.140:49174
udp 213.192.65.74:40839 10.0.1.12:40839   65.55.223.16:40021 65.55.223.16:40021
udp 213.192.65.74:40839 10.0.1.12:40839   65.55.223.23:40024 65.55.223.23:40024
udp 213.192.65.74:40839 10.0.1.12:40839   65.55.223.38:40034 65.55.223.38:40034
udp 213.192.65.74:40839 10.0.1.12:40839   83.81.169.228:56975 83.81.169.228:56975
udp 213.192.65.74:40839 10.0.1.12:40839   83.218.98.159:5954 83.218.98.159:5954
udp 213.192.65.74:40839 10.0.1.12:40839   111.221.74.14:40012 111.221.74.14:40012
udp 213.192.65.74:40839 10.0.1.12:40839   111.221.74.15:40024 111.221.74.15:40024
udp 213.192.65.74:40839 10.0.1.12:40839   111.221.74.30:40004 111.221.74.30:40004
udp 213.192.65.74:40839 10.0.1.12:40839   111.221.77.143:40045 111.221.77.143:40045
udp 213.192.65.74:40839 10.0.1.12:40839   111.221.77.152:40021 111.221.77.152:40021
udp 213.192.65.74:40839 10.0.1.12:40839   111.221.77.166:40023 111.221.77.166:40023
udp 213.192.65.74:40839 10.0.1.12:40839   129.16.138.32:10159 129.16.138.32:10159
udp 213.192.65.74:40839 10.0.1.12:40839   145.97.202.245:37174 145.97.202.245:37174
udp 213.192.65.74:40839 10.0.1.12:40839   157.55.130.149:40044 157.55.130.149:40044
udp 213.192.65.74:40839 10.0.1.12:40839   157.56.52.26:40015 157.56.52.26:40015
udp 213.192.65.74:40839 10.0.1.12:40839   157.56.52.27:40030 157.56.52.27:40030
udp 213.192.65.74:40839 10.0.1.12:40839   157.56.52.29:40038 157.56.52.29:40038
udp 213.192.65.74:40839 10.0.1.12:40839   157.56.52.34:40009 157.56.52.34:40009
udp 213.192.65.74:40839 10.0.1.12:40839   157.56.52.37:40021 157.56.52.37:40021
udp 213.192.65.74:40839 10.0.1.12:40839   188.205.97.185:58695 188.205.97.185:58695
tcp 213.192.65.74:44793 10.0.1.12:44793   157.56.126.107:443 157.56.126.107:443
tcp 213.192.65.74:45209 10.0.1.12:45209   199.47.219.159:443 199.47.219.159:443
tcp 213.192.65.74:45479 10.0.1.12:45479   80.247.163.112:777 80.247.163.112:777
tcp 213.192.65.74:46054 10.0.1.12:46054   80.247.163.35:777  80.247.163.35:777
tcp 213.192.65.74:47295 10.0.1.12:47295   83.218.98.159:5954 83.218.98.159:5954
tcp 213.192.65.74:48749 10.0.1.12:48749   67.228.181.218:80  67.228.181.218:80
tcp 213.192.65.74:49641 10.0.1.12:49641   199.7.59.72:80     199.7.59.72:80
tcp 213.192.65.74:49836 10.0.1.12:49836   157.55.56.141:40039 157.55.56.141:40039
tcp 213.192.65.74:50120 10.0.1.12:50120   23.62.127.139:443  23.62.127.139:443
tcp 213.192.65.74:51745 10.0.1.12:51745   31.13.80.20:80     31.13.80.20:80
tcp 213.192.65.74:53752 10.0.1.12:53752   195.2.255.11:22    195.2.255.11:22
tcp 213.192.65.74:54580 10.0.1.12:54580   129.16.138.32:10159 129.16.138.32:10159
tcp 213.192.65.74:56832 10.0.1.12:56832   54.243.219.91:443  54.243.219.91:443
tcp 213.192.65.74:57134 10.0.1.12:57134   2.16.4.176:443     2.16.4.176:443
tcp 213.192.65.74:57137 10.0.1.12:57137   2.16.4.176:443     2.16.4.176:443
tcp 213.192.65.74:58098 10.0.1.12:58098   157.56.248.166:443 157.56.248.166:443
tcp 213.192.65.74:58153 10.0.1.12:58153   157.56.248.166:443 157.56.248.166:443
tcp 213.192.65.74:58608 10.0.1.12:58608   88.198.132.241:443 88.198.132.241:443
tcp 213.192.65.74:58627 10.0.1.12:58627   88.198.132.241:443 88.198.132.241:443
tcp 213.192.65.74:58673 10.0.1.12:58673   199.47.216.172:443 199.47.216.172:443
tcp 213.192.65.74:59333 10.0.1.12:59333   145.97.202.245:37174 145.97.202.245:37174
tcp 213.192.65.74:59365 10.0.1.12:59365   93.138.47.24:44247 93.138.47.24:44247
tcp 213.192.65.74:60117 10.0.1.12:60117   81.26.219.122:80   81.26.219.122:80
tcp 213.192.65.74:60118 10.0.1.12:60118   81.26.219.122:80   81.26.219.122:80
tcp 213.192.65.74:60119 10.0.1.12:60119   81.26.219.122:80   81.26.219.122:80
Anybody?
During last month I didn't have time to work on it, but recently I started from scratch. I restored default router configuration and configured everything as it is present on
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml#topic5 and
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml#topic9 - nothing less nothing more. Unfortunately this still doesn't work for me.
I am confused... Guys, please help - what am I doing wrong ?
OK, I finally figured out why it was not working.
Of course IOS configuration was correct. The problem was in gateway of the 10.0.0.24 server.
Because currently my Cisco router is still in testing stage, all  servers are not using it as default gateway. In order to have working  port forwarding I had to change gateway on the server to 10.0.0.1 .  After that, everything started to work.
Thank you all of you, who participated in my problem and shared knowledge.
Please rate helpful posts
