Something wrong with my NAT lab
jamesgonzo
I have been trying to test NAT between offices that use the same LAN IP range. I based my config on another post in this forum.
Below are the 2 configs:
R0#sh run
Building configuration...
Current configuration : 950 bytes
version 12.4
hostname R0
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 15
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip domain lookup
interface Loopback0
ip nat inside
interface Serial0/0
ip address 10.1.1.1 255.255.255.0
ip nat outside
clock rate 128000
ip forward-protocol nd
ip route 172.19.1.0 255.255.255.0 10.1.1.2
ip http server
no ip http secure-server
ip nat inside source static network 192.168.1.0 172.19.2.0 /24
control-plane
line con 0
line aux 0
line vty 0 4
login
end
R1#sh run
Current configuration : 911 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
interface Loopback0
ip nat inside
interface Serial0/0
ip address 10.1.1.2 255.255.255.0
ip nat outside
ip route 172.19.2.0 255.255.255.0 10.1.1.1
ip http server
ip nat inside source static network 192.168.1.0 172.19.1.0 /24
control-plane
line con 0
line aux 0
line vty 0 4
login
end
If I ping from R0 and use the loopback as the source I get no replies:
R0#ping 172.19.1.1 source loopback 0
Sending 5, 100-byte ICMP Echos to 172.19.1.1, timeout is 2 seconds:
Packet sent with a source address of 192.168.1.1
Success rate is 0 percent (0/5)
R0#
However I get this output on the remote R1 router, it is like is is receiving the ping but can't route/NAT it back over the WAN link.
R1#
*Mar 1 00:27:55.182: NAT*: s=192.168.1.1, d=172.19.1.1->192.168.1.1 [45]
*Mar 1 00:27:55.186: ICMP: echo reply sent, src 192.168.1.1, dst 192.168.1.1
*Mar 1 00:27:55.190: ICMP: echo reply rcvd, src 192.168.1.1, dst 192.168.1.1
*Mar 1 00:27:57.161: NAT*: s=192.168.1.1, d=172.19.1.1->192.168.1.1 [46]
*Mar 1 00:27:57.165: ICMP: echo reply sent, src 192.168.1.1, dst 192.168.1.1
*Mar 1 00:27:57.169: ICMP: echo reply rcvd, src 192.168.1.1, dst 192.168.1.1
*Mar 1 00:27:59.088: NAT*: s=192.168.1.1, d=172.19.1.1->192.168.1.1 [47]
*Mar 1 00:27:59.092: ICMP: echo reply sent, src 192.168.1.1, dst 192.168.1.1
*Mar 1 00:27:59.096: ICMP: echo reply rcvd, src 192.168.1.1, dst 192.168.1.1
*Mar 1 00:28:01.071: NAT*: s=192.168.1.1, d=172.19.1.1->192.168.1.1 [48]
*Mar 1 00:28:01.075: ICMP: echo reply sent, src 192.168.1.1, dst 192.168.1.1
*Mar 1 00:28:01.079: ICMP: echo reply rcvd, src 192.168.1.1, dst 192.168.1.1
*Mar 1 00:28:03.075: NAT*: s=192.168.1.1, d=172.19.1.1->192.168.1.1 [49]
*Mar 1 00:28:03.079: ICMP: echo reply sent, src 192.168.1.1, dst 192.168.1.1
*Mar 1 00:28:03.083: ICMP: echo reply rcvd, src 192.168.1.1, dst 192.168.1.1
*Mar 1 00:28:35.123: NAT: expiring 172.19.1.1 (192.168.1.1) icmp 8 (8)
Am I missing something?
10 Replies 10
Marwan ALshawi
try to clear ip nat translation
Istvan_Rabai
Level 7
Level 7
I think the problem is that when the packet arrives to R1 the source address is 192.168.1.1 and the destination address 172.19.1.1 is translated to 192.168.1.1, the same address.
When the reply to the ping is sent from 192.168.1.1, the destination address is the same, 192.168.1.1, so the reply is sent to itself, and it never gets out of R1 and never reaches R0.
You can seee it from the debug output:
within the same router.
Cheers:
Istvan
i think Istvan
thats mean R1 not doing NAT
but i did same as your config copy past
becuase i found it right
and it is working
look bellow:
R0#ping 172.19.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 120/168/224 ms
R1#debug ip nat detailed
IP NAT detailed debugging is on
R1#
*Apr 6 10:16:31.319: NAT*: o: icmp (10.1.1.1, 1) -> (172.19.1.1, 1) [5]
*Apr 6 10:16:31.319: NAT*: s=10.1.1.1, d=172.19.1.1->192.168.1.1 [5]
*Apr 6 10:16:31.323: ICMP: echo reply sent, src 192.168.1.1, dst 10.1.1.1
*Apr 6 10:16:31.327: NAT: i: icmp (192.168.1.1, 1) -> (10.1.1.1, 1) [5]
*Apr 6 10:16:31.327: NAT: s=192.168.1.1->172.19.1.1, d=10.1.1.1 [5]
*Apr 6 10:16:31.451: NAT*: o: icmp (10.1.1.1, 1) -> (172.19.1.1, 1) [6]
*Apr 6 10:16:31.451: NAT*: s=10.1.1.1, d=172.19.1.1->192.168.1.1 [6]
*Apr 6 10:16:31.455: ICMP: echo reply sent, src 192.168.1.1, dst 10.1.1.1
*Apr 6 10:16:31.455: NAT: i: icmp (192.168.1.1, 1) -> (10.1.1.1, 1) [6]
*Apr 6 10:16:31.455: NAT: s=192.168.1.1->172.19.1.1, d=10.1.1.1 [6]
*Apr 6 10:16:31.619: NAT*: o: icmp (10.1.1.1, 1) -> (172.19.1.1, 1) [7]
*Apr 6 10:16:31.619: NAT*: s=10.1.1.1, d=172.19.1.1->192.168.1.1 [7]
*Apr 6 10:16:31.623: ICMP: echo reply sent, src 192.168.1.1, dst 10.1.1.1
*Apr 6 10:16:31.627: NAT: i: icmp (192.168.1.1, 1) -> (10.1.1.1, 1) [7]
*Apr 6 10:16:31.627: NAT: s=192.168.1.1->172.19.1.1, d=10.1.1.1 [7]
thats why i told you try to clear ip nat ternaslation becuase maybe u need a refresh
good luck
Hi, "ping 172.19.1.1" does work for me too, but try "ping 172.19.1.1 source loopback 0"
tim1csolutions
Try configuring it this way:
R0:
ip nat outside source static network 192.168.1.0 172.19.1.0 /24
R1:
(Remove NAT configuration)
Timothy Chin
CCIE #23866 (R&S)
I added what you mentioned so the NAT is on one side only but the ping only works from oneside (R1 > R0), I have the configs and debugs in the e attached file.
try pinging from R0 using the loopback interface as the source.
Timothy Chin
CCIE #23866 (R&S)
Not able to ping:
R0#
what is seen on R1 when I did the above:
*Mar 1 00:05:33.078: NAT*: o: icmp (192.168.1.1, 5) -> (172.19.1.1, 5) [25]
*Mar 1 00:05:33.078: NAT*: s=192.168.1.1, d=172.19.1.1->192.168.1.1 [25]
*Mar 1 00:05:33.082: ICMP: echo reply sent, src 192.168.1.1, dst 192.168.1.1
*Mar 1 00:05:33.086: ICMP: echo reply rcvd, src 192.168.1.1, dst 192.168.1.1
*Mar 1 00:05:35.097: NAT*: o: icmp (192.168.1.1, 5) -> (172.19.1.1, 5) [26]
*Mar 1 00:05:35.101: NAT*: s=192.168.1.1, d=172.19.1.1->192.168.1.1 [26]
*Mar 1 00:05:35.105: ICMP: echo reply sent, src 192.168.1.1, dst 192.168.1.1
*Mar 1 00:05:35.109: ICMP: echo reply rcvd, src 192.168.1.1, dst 192.168.1.1
*Mar 1 00:05:36.936: NAT*: o: icmp (192.168.1.1, 5) -> (172.19.1.1, 5) [27]
*Mar 1 00:05:36.936: NAT*: s=192.168.1.1, d=172.19.1.1->192.168.1.1 [27]
*Mar 1 00:05:36.936: ICMP: echo reply sent, src 192.168.1.1, dst 192.168.1.1
*Mar 1 00:05:36.936: ICMP: echo reply rcvd, src 192.168.1.1, dst 192.168.1.1
*Mar 1 00:05:38.835: NAT*: o: icmp (192.168.1.1, 5) -> (172.19.1.1, 5) [28]
*Mar 1 00:05:38.839: NAT*: s=192.168.1.1, d=172.19.1.1->192.168.1.1 [28]
*Mar 1 00:05:38.843: ICMP: echo reply sent, src 192.168.1.1, dst 192.168.1.1
*Mar 1 00:05:38.847: ICMP: echo reply rcvd, src 192.168.1.1, dst 192.168.1.1
*Mar 1 00:05:41.063: NAT*: o: icmp (192.168.1.1, 5) -> (172.19.1.1, 5) [29]
*Mar 1 00:05:41.063: NAT*: s=192.168.1.1, d=172.19.1.1->192.168.1.1 [29]
*Mar 1 00:05:41.067: ICMP: echo reply sent, src 192.168.1.1, dst 192.168.1.1
*Mar 1 00:05:41.075: ICMP: echo reply rcvd, src 192.168.1.1, dst 192.168.1.1
*Mar 1 00:06:02.570: NAT: expiring 172.19.1.1 (192.168.1.1) icmp 4 (4)
*Mar 1 00:06:41.546: NAT: expiring 172.19.1.1 (192.168.1.1) icmp 5 (5)
Try one more thing. Since it is local router traffic on R0 configure this:
access-list 100 permit ip host 192.168.1.1 any
route-map LOCAL permit 10
match ip address 100
set interface loopback0
ip local policy route-map LOCAL
then ping 172.19.1.1 using the loopback interface as the source. What you are doing here is "directing" local router traffic to interface loopback0 which is your inside interface then the traffic is routed out the outside interface so the NAT policy can take effect.
Timothy Chin
CCIE #23866 (R&S)
I think that worked:
r0:
Sending 1, 100-byte ICMP Echos to 172.19.1.1, timeout is 2 seconds:
Success rate is 100 percent (1/1), round-trip min/avg/max = 277/277/277 ms
R0#
*Mar 1 00:05:05.600: NAT: i: icmp (192.168.1.1, 6) -> (172.19.1.1, 6) [30]
*Mar 1 00:05:05.604: NAT: s=192.168.1.1->172.19.2.1, d=172.19.1.1 [30]
*Mar 1 00:05:05.861: NAT*: o: icmp (192.168.1.1, 6) -> (172.19.2.1, 6) [30]
*Mar 1 00:05:05.865: NAT*: o: icmp (192.168.1.1, 6) -> (172.19.2.1, 6) [30]
*Mar 1 00:05:05.865: NAT*: s=192.168.1.1, d=172.19.2.1->192.168.1.1 [30]
*Mar 1 00:05:05.869: ICMP: echo reply rcvd, src 192.168.1.1, dst 192.168.1.1
*Mar 1 00:05:06.398: NAT: expiring 172.19.2.1 (192.168.1.1) icmp 5 (5)
*Mar 1 00:05:06.402: NAT: expiring 172.19.2.1 (192.168.1.1) icmp 5 (5)
R1:
*Mar 1 00:05:05.620: NAT*: o: icmp (172.19.2.1, 6) -> (172.19.1.1, 6) [30]
*Mar 1 00:05:05.625: NAT*: s=172.19.2.1, d=172.19.1.1->192.168.1.1 [30]
*Mar 1 00:05:05.629: ICMP: echo reply sent, src 192.168.1.1, dst 172.19.2.1
*Mar 1 00:05:06.350: NAT: expiring 172.19.1.1 (192.168.1.1) icmp 5 (5)
This is a little more complicated than I first thought, should the first NAT setup I had of worked or is this policy map they I should do it? I'm not clear on the commands you gave me.
