sonet what osi layer?
sarahr202
Level 5
Level 5
Hi everybody
I am just learning about sonet .Which OSI layer does sonet map to ?
thanks and have a great day
4 Accepted Solutions
singhaam007
Level 3
Level 3
hi Sarah,
it use layer 1 or we can say physical layer
http://compnetworking.about.com/od/hardwarenetworkgear/l/aa092800a.htm
hope this will help.
thanks
Reza Sharifi
Hi Sarah,
Sonet in just a type physical interface just like Ethernet is:
SONET defines interface standards at the physical layer of the
OSI
seven-layer model. The standard defines a hierarchy of interface rates that allow data streams at different rates to be
multiplexed
.  SONET establishes Optical Carrier (OC) levels from 51.8 Mbps (OC-1) to  9.95 Gbps (OC-192). Prior rate standards used by different countries  specified rates that were not compatible for multiplexing. With the  implementation of SONET,
http://www.webopedia.com/TERM/S/SONET.html
singhaam007
Level 3
Level 3
this is a really good link and will help you lot
https://learningnetwork.cisco.com/docs/DOC-15624
thanks
Hello Sarah,
SONET  STS-1 supports 51.84 Mbps.
check these links for more detail.
http://www.javvin.com/protocolSONET.html
http://www.infocellar.com/networks/Telecom101/speeds.htm
thanks
6 Replies 6
singhaam007
Level 3
Level 3
hi Sarah,
thanks
Reza Sharifi
Hi Sarah,
OSI
multiplexed
thanks Reza and Singh
Does It mean when we speak of sonet, we are talking about the above mentioned data rates over fiber only not copper ?
Or sonet can also use copper to support the above mentioned data rates?
thanks
Hello Sarah,
thanks
SONET/SDH can be used in an ATM or non-ATM environment. Packet Over  SONET/SDH (POS) maps IP datagrams into the SONET frame payload using  Point-to-Point Protocol (PPP).In the ATM enviroment, connections to  SONET/SDH lines may be via multi-mode, single-mode or UTP.
please consider the highlighted line above:
does it mean ip packet---> ppp---> Sonet framing ?
thanks
singhaam007
Level 3
Level 3
thanks
