Showing results forĀ
Search instead forĀ
Did you mean:Ā
Source routing fail
alopez
Community Member
I have a router cisco 7604 VXR with two outside connections, each one associated to a set of addresses. I have defined a default gateway for one  of the set of addresses and a source routing to define the gateway for the other set but it doesn't work. The configuration is:
interface FastEthernet0/1.5
encapsulation dot1Q 5
ip address 147.13.30.161 255.255.255.224
ip flow monitor flow-monitor-smart-1 output
ip flow ingress
ip flow egress
ip policy route-map CCA_GATEWAY
ip ospf message-digest-key 1 md5 7 1A4D169404421B1F027A7A
access-list 101 permit ip 147.13.30.160 0.0.0.31 any
route-map CCA_GATEWAY permit 10
match ip address 101
set ip default next-hop 172.31.50.2      (address of the next router. I arrive to it)
When I do a show route-map CCA_GATEWAY I see that "the number of policy routing  matches" increase but the router is sending the packets to the wrong gateway.
route-map CCA_GATEWAY, permit, sequence 10
  Match clauses:
    ip address (access-lists): 101
  Set clauses:
  Policy routing matches: 2336130 packets, 2068948582 bytes
What does it happen?
IOS version 15.1
Albert
Richard Burts
Albert
I suspect that the issue is in the way that you are doing the set in the route map. You are setting the default netxt hop:
but based on what you have described I believe that it would be better to set the next hop directly:
set ip next-hop 172.31.50.2
can you give this a try and let us know if it improves the situation?
Rick
Rick
Richard Burts
Albert
Rick
Rick
Thanks Rick, Now it is working.
Albert
I am glad that my suggestion did help you to resolve your problem. Thank you for posting back to the forum indicating that the problem was solved (and thank you for the rating). It makes the forum more useful when people can read about a problem and can tell from the marking of the post that they will read suggestions which lead to the solution of the problem.
I encourage you to continue your participation in the forum.
Rick
Rick
