Source Specific Multicast (SSM)
Robert Plunkett
Level 2
Level 2
Does anyone know how to configure Source specific Multicast (SSM) on a cisco  switch?
shambhu.kumar
Hello Robert,
Enable multicast routing (global)
ip multicast-routing [distributed]
Enable SSM on all routers. If you do not specify a group, then the 232.0.0.0/8 range will be used.
ip pim ssm [default|range]
Enable PIM Sparse at interface level
ip pim sparse-mode
Enable IGMPv3 on the source and receiver
ip igmp version 3
Check this link,
https://mrncciew.com/2021/04/12/source-specific-multicast-ssm/
Hope this will help.
5 Replies 5
Joseph W. Doherty
On a L3 switch, correct?
Mark Elsen
  - FYI : https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-0_2_se/configuration/guide/3750x_cg/swmcast.html#97854
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
shambhu.kumar
Hello Robert,
ip pim sparse-mode
ip igmp version 3
Check this link,
Thank you very much.
