SPAN configuration between cisco 4500 in VSS and firewall fortinet 1200
crisol
We need to SPAN port channel 16 (members te1/1/7 and te2/1/7) as source and destination to same switch at interface te1/1/9.
Current configuration below:
interface Port-channel16
switchport
switchport access vlan 120
switchport mode access
interface TenGigabitEthernet1/1/7
channel-group 16 mode desirable
interface TenGigabitEthernet2/1/7
interface TenGigabitEthernet1/1/9
interface TenGigabitEthernet2/1/9
monitor session 2 source interface Po16
monitor session 2 destination interface Te2/1/9
monitor session 10 source interface Po16
monitor session 10 destination interface Te1/1/9
RDW_CORE_VSS#sh etherchannel sum
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use N - not in use, no aggregation
f - failed to allocate aggregator
M - not in use, minimum links not met
m - not in use, port not aggregated due to minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
A - formed by Auto LAG
Number of channel-groups in use: 12
Number of aggregators: 12
Group Port-channel Protocol Ports
1 Po1(SU) - Te1/1/15(P) Te1/1/16(P)
2 Po2(SU) - Te2/1/15(P) Te2/1/16(P)
10 Po10(SU) - Te1/1/1(P) Te2/1/1(P)
11 Po11(SD) -
12 Po12(SU) - Te1/1/3(P) Te2/1/3(P)
13 Po13(SU) - Te1/1/4(P) Te2/1/4(P)
14 Po14(SD) PAgP Te1/1/5(D) Te2/1/5(D)
15 Po15(SD) PAgP Te1/1/6(D) Te2/1/6(D)
16 Po16(SD) PAgP Te1/1/7(I) Te2/1/7(I)
17 Po17(SU) PAgP Te1/1/8(P) Te2/1/8(P)
30 Po30(SU) - Te1/1/2(P) Te2/1/2(D)
128 Po128(SU) LACP Te1/1/13(P) Te2/1/13(P)
Questions:
1. Do we need to specidy a vlan at the destination interface te1/1/9 or te2/1/9? Currently those interfaces are blank.
2. No traffic is seen in the destination side by the capturing device. What is missing in our configuration?
Crisol
Francesco Molino
No need to add a vlan for your span receiver.
You should configure both interface member as source because there're in individual more that means not bundled into port-channel.
You certainly have an issue on the other end of the port-channel that's why there're not bundled
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
