SPAN Configuration Requirement
ranjit123
Level 3
Level 3
Dear All,
Attached is the diagram of the requirement..
Details are as below
1> Active - FW connected to 3650 Switch Stack with single port connectivity
2> Passive - FW connected to 3650 Switch Stack with single port connectivity
4> Connectivity between FW and Stack switch is using port-channel ( grouping of 2 ports )
3> One Snifer Devices is connected to Stack-SW-1 and another Snifer Device is connected to Stack-SW-2
Requirement is as below
1> Source ports for sniffing will be the port channel ports connected to the firewall and destination will be the Sniffer device connected on the Stack-SW-1 ( refer to the diagram the snifer device on the left hand side )
2> Source ports for sniffing will be the port channel ports connected to the firewall and destination will be the Sniffer device connected on the Stack-SW-2 ( refer to the diagram the snifer device on the right hand side )
What is the easiest way that i can do this... should i configure 2 different monitor sessions with same source ports and  different destination port for each session
OR
Does a single session support 2 different destination port on 3650-STACK..
Kindly Guide Me.....
Thanks a lot
Hello
Yes looks about right.
Kind Regards
Paul
11 Replies 11
Reza Sharifi
Since the 2 3650 switches are stacked, they are logically one switch. So, you really only need one of the switches to be the destination device. Just make the destination one of the ports on switch-1.
ranjit123
Level 3
Level 3
Hello Reza,
Thanks a lot for your reply but the requirements is different and as I updated, can I configure two monitor sessions with same port's and 2 different destination port's..
Scott Hodgdon
Ranjit,
How are you creating a port channel between two different physical firewalls ? The only way I see that working is if the two firewalls are seen as one logical device.
What version of 3650 IOS are you running ?
Cheers,
Scott Hodgdon
Senior Technical Marketing Engineer
Enterprise Networking and Cloud Group
Hello Scott,
Thanks a lot for your guidance as alwayz..
The FW are in Active-Passive mode...
Hello
A span source/destination port cannot be both at the same time, also only a single destination port is allowed per monitor session
As you want to span a PC  make sure the destination port can take the span traffic , sourcing from a PC to the destination port could overwhelm
Kind Regards
Paul
Hello paul...
Thanks for your reply...
Will the below configuration work...
Monitor session 1
Source port-channel 1 ( which contains 2 ports connected to FW )
Destination port G1/1 ( port on stack- SW 1 which is connected to snifer -1 )
Monitor session 2
Destination port G2/1 ( port on stack- SW 2 which is connected to snifer -2 )
Hello
Yes, it should work, but why would you want to do this, the traffic being monitored is the same?
However instead of the defining the PC as a whole as source you could chose the individual physical port of the PC in two different span sessions
Example:
etherchannel
Gi0/0 Gi0/1
monitor session 1 source interface Gi0/0
monitor session 1 destination interface Gi0/2
monitor session 2 source interface Gi0/1
monitor session 2 destination interface Gi0/3
Kind Regards
Paul
Hello Paul,
Can individual port's of port-channel be part of 2 span sessions ...
Hello
Yes -
A span session can be sourced either from the whole PC or part of it (ie the physcal ports)
Kind Regards
Paul
Hello Paul,
Thanks a lot for your replies this simplifies my task a lot...
-------------_------------------------
Can You Configure SPAN on an EtherChannel Port?
An EtherChannel does not form if one of the ports in the bundle is a SPAN destination port. If you try to configure SPAN in this situation, the switch tells you:
Channel port cannot be a Monitor Destination Port
Failed to configure span feature
You can use a port in an EtherChannel bundle as a SPAN source port.
So now my configuration will be as below..
Monitor session 1
Source port G1/1 ( port connected to active FW on the stack SW-1)
Destination port G1/2 ( port can stack SW-1 where sniffer decive 1 is connected )
Monitor session 2
Source port G2/1 ( port connected to passive firewall on stack SW-2 )
Destination port G2/2 ( port can stack SW-2 where sniffer decive 2 is connected )
Hello
Kind Regards
Paul
