Switch Port config quick question
yeahyeah1
Hello
Need to replace two switches and need some assistance to clarify the port config
Switchport set as trunk
So it will send tagged voice traffic via the voice vlan
And untagged to native vlan 3?
interface FastEthernet1/0/14
description **** IP PHONE OR PC ****
switchport trunk native vlan 3
switchport trunk pruning vlan 5-1001
switchport mode trunk
switchport voice vlan 203
Thank you
balaji.bandi
Is this Port Trunk between Switch or End device ?
Between Switch Trunk as below : so you taking control to allow only Data and Voice VLAN :
interface fastethernet x/x
switchport trunk allowed vlan 2,203
Access port to device connected : ( depends on requirement) most case we use as below :
switchport mode access
switchport access vlan 3
BB
Steven Case
Yeah, this configuration makes very little sense. Based on what you have here I can only infer that the device that was connected to the phone was virtualizing a network card (like a Hypervisor software of some kind). If this is the whole configuration on the port, it's saying the following:
Allow a phone to be connected and run in a different VLAN as data (switchport voice vlan 203)
The data coming through this device will be tagged with multiple VLANs present (switchport mode trunk)
As it's a trunk, here's the encapsulation (switchport trunk encapsulation dot1q)
Don't tag VLAN 3 (switchport trunk native vlan 3)
On this trunk, as VTP is used, don't learn or allow VLANS 5 through 1001 (switchport trunk pruning 5 - 1001)
Now the description in the most alarming part to me... this implies that this is the default configuration for all ports on the switch, and possibly throughout the entire network. I don't see a BPDUGuard on a port that is always up as a trunk, nor any spanning tree, so... I mean... switching loops and VTP domain jacking is possible. That's fun.
I know you didn't ask for advice, but here's what I would do:
switchport access vlan 3 (looks like that's what the admin was going for)
switchport voice vlan 203 (if no phone, then no problem)
If you do port security or plan on it in the future, definitely explicitly add:
Call it a day. Get that trunk stuff off of those ports.
Hello
In short yes it will
Data vlan 3 =untagged
Voice vlan203 = Tagged
Kind Regards
Paul
