SPAN on 2950
shahin shahini
I am trying to enable the monitoring on a cisco 2950-24 switch but when run the command
monitor session 1 source ......
get the message invalid in put.
is this means I cannot enable the SPAN on this switch?
Hello
What ios are you ruining?
show version
show monitor session x
Kind Regards
Paul
Thanks for reply,
this is the ios version
Switch#show version
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA4, RELEASE SOFTWARE(fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 18-May-05 22:31 by jharirba
Image text-base: 0x80010000, data-base: 0x80562000
ROM: Bootstrap program is is C2950 boot loader
Switch uptime is 4 hours, 29 minutes, 11 seconds
Cisco WS-C2950-24 (RC32300) processor (revision C0) with 21039K bytes of memory.
Processor board ID FHK0610Z0WC
Last reset from system-reset
Running Standard Image
24 FastEthernet/IEEE 802.3 interface(s)
63488K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 0004.9A43.667E
Motherboard assembly number: 73-5781-09
Power supply part number: 34-0965-01
Motherboard serial number: FOC061004SZ
Power supply serial number: DAB0609127D
Model revision number: C0
Motherboard revision number: A0
Model number: WS-C2950-24
System serial number: FHK0610Z0WC
Configuration register is 0xF
