SPAN on 6500 series
jagdev.dhaliwal
Hello All,
I want to configure SPAN  on 6500 series for SNORT IDS, it has multiple Vlan and all Vlan are of layer 2,  Can you please guide me how can I achieve this?
Thanks in anticipation
Jagdev
Hi Jagdev,
Following configuration will work for local span and will give all traffic
output on the destination port which you have configured Gi9/10
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Ganesh Hariharan
Hello All,
Jagdev
Hi Jagdev,
Check out the belowl ink for span configuration on 6500 series switches
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/configuration/guide/span.html
Hope to Help !!
Ganesh.H
Hi Ganesh,
Thanks for reply,  As per the document and my knoweldge i can configure SPAN as i have given configuration example bleow, and that should not make any raise in CPU utilization as 6500 deos not use CPU to switch Packets or mirror packets.
monitor session 1 source  Vlan 1-100 , 350
monitor session 1 destination interface G9/10
am i right and can i go ahead with this configuration?
Jagdev
Hi Jagdev,
Hope to Help !!
Ganesh.H
