SPAN or VACL Capture ?
pstuder
Frequent Visitor
Frequent Visitor
I have a customer that is trying to set up what essentially amounts to a third party RMON probe on their 6509/Sup720/12.2(18)SXF switch. There is only 1 port that can be used on the probe, so through this single port, the mirrored traffic AND the managament traffic of the probe must pass. As I have discovered in my configuration of SPAN, the destination port must be dedicated to the received traffic - no other interactive traffic w/ the probe is allowed. Are the restrictions the same for VACL capture? If so, are there any work-arounds to enable this configuration? Any help is greatly appreciated!!
royalblues
Level 11
Level 11
If the SPAN destination port is connected to another device and you enable reception of incoming packets (using the inpkts enable keywords), the SPAN destination port receives traffic for whatever VLAN the SPAN destination port belongs to.
However, the SPAN destination port does not participate in spanning tree for that VLAN. Use caution when using the inpkts keyword to avoid creating network loops with the SPAN destination port or assigning the SPAN destination port to an unused VLAN.
Narayan
Thanks for the info, but I think that the "inpkts enable" on the destination port is for CatOS only ... is there an equivalent command for IOS?
