span port channel
smartboy2255
Hi All,
   Is there any option to span port channel of Cisco 6500 Switch.If possible What is the configuration for the same..
Pls help..
Ajith
2 Accepted Solutions
mvsheik123
Level 7
Level 7
Yes..you can. on switch running cisco IOS.. use below command..
6513(config)#monitor session 20 source interface port-channel
6513(config)#monitor session 20 destination interface gig
hth
MS
Reza Sharifi
You can, but the Portchannel has to be in on mode.  You cannot use it wilt LACP or PAGP.
Note:
From Cisco IOS Software Release  12.2(33)SXH and later, PortChannel interface can be a destination port.  Destination EtherChannels do not support the Port Aggregation Control  Protocol (PAgP) or Link Aggregation Control Protocol (LACP) EtherChannel  protocols; only the on mode is supported, with all EtherChannel  protocol support disabled.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015c612.shtml
Reza
mvsheik123
Level 7
Level 7
hth
MS
Reza Sharifi
Note:
Reza
What I read from the above, it only means the destination is a port channel then PAgP and LACP won't work. There isn't any mentioning if the source is a port channel. Can I assume it would work fine if the source was a port channel while the destination was any other types as such fast, giga, tengiga?.
