Does anyone get an error when trying to upgrade 3750 switch?
tdennehy
Level 2
Level 2
I get the following when trying to load IOS to a switch so I can then stack it with another:
Error: The image in the archive which would be used to upgrade
Error: system number 1 does not support that system type.
I found that /allow-feature-upgrade helped others, but when I tried it, it failed to help.
Any ideas?
archive download-sw /allow-feature-upgrade /overwrite tftp://10.70.39.40/c3750-ipbasek9-tar.122-46.SE.tar
Loading c3750-ipbasek9-tar.122-46.SE.tar from 10.70.39.40 (via Vlan240): !!!!!!!
examining image...
extracting info (105 bytes)
extracting c3750-ipbasek9-mz.122-46.SE/info (611 bytes)
Stacking Version Number: 1.40
System Type:             0x00000000
  Ios Image File Size:   0x008C7A00
  Total Image File Size: 0x00B4CA00
  Minimum Dram required: 0x08000000
  Image Suffix:          ipbasek9-122-46.SE
  Image Directory:       c3750-ipbasek9-mz.122-46.SE
  Image Name:            c3750-ipbasek9-mz.122-46.SE.bin
  Image Feature:         IP|LAYER_3|SSH|3DES|MIN_DRAM_MEG=128
Leo Laohoo
Can you give us a little bit more info?
Ok, so you are upgrading only one switch.  So please post the output to the command "sh switch detail".
