SPAN with RSPAN - Help !
sdawson35
Level 4
Level 4
I have 2 x 3560 switches that are trunked across Port 8, I then have an inbound source connection on each of the Port 2's.
I need to capture the traffic from both of the Port 2's to a single port on one of the 3560's.
So
Switch A
Inbound Traffic = Port 2
Trunk = Port 8
monitor session 1 source interface Gi0/2
monitor session 1 destination remote vlan 901
Switch B
Sniffer = Port 7
Trunk = Port 8
monitor session 2 source interface Gi0/2
monitor session 2 destination interface Gi0/7
How do I get the span session from Switch A to destination interface on Switch B as well as the source on Switch B to destination on Switch B
Scott.
Reza Sharifi
Have a look at the config guide for the 3560 series switches.  It has examples of SPAN and RSPAN with configs.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_52_se/configuration/guide/swspan.html#wp1081130
Hi Scott,
You can use the monitor session session_number source command multiple times to configure multiple source ports.
So on Switch B, configure.
monitor session 2 source interface vlan 901
or
monitor session 2 source interface Gi0/2 , vlan 901
-Subhash
