SPAN
nnn_sss22
SPAN works same like wireshark?
Can someone show me SPAN output? thanks
Julio E. Moisa
Understanding the question, you are asking if SPAN sessions work like wireshark. Well SPAN sessions are used to identify the kind of traffic passing through a VLAN, access port (s) or trunk interface(s) but you cannot see this traffic unless you are using a sniffer software like Wireshark or PRTG or others.
SPAN and Wireshark (sniffer) can have the same purpose but in order to read the SPAN info you need a sniffer.
Hope it is useful.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Reza Sharifi
Yes, you span a port and than you use wireshark to read/see the output.
see link for installing wireshark and reading the output
https://www.youtube.com/watch?v=-aTGL4M0db4
Julio E. Moisa
Hope it is useful.
