Showing results forĀ
Search instead forĀ
Did you mean:Ā
SPAN
orama
just a quick clarification on SPAN, I ran into a debate with a colleague.
Span has two ports, destination and source.
Does the destination port need to have a network analyzer attached to it or can I have my network analyzer attached  in a random port  different than source and destination but in the same switch?
johnd2310
Level 8
Level 8
Analyser goes into the destination port.
John
**Please rate posts you find helpful**
etoromol
Based on the original design and logic of the application, it is not possible to have the capture attached into a different port from the one you specify as the destination interface. You can source from a VLAN interface (attached to multiple interfaces), however with SPAN the destination is always a single interface, where the capture should be attached.
Regards.
