Spanning and tree and static routing
WC415
I am struggling with my networking lab project, I'm familiar with the commands to apply but I can't quite figure out on which devices they should be applied on as I have tried lots of scenarios with no luck.
- I need to configure spanning tree between the 3 switches and primary and secondary root bridges for the management vlan (S1,S2,S3).
- Configure static routes on routers R1 and R2 (no RIP , no EIGRP, and no OSPF)
- The Pings I'm trying to do are:
 * PC1 to PC2
 * PC1 and PC2 to S1
 * PC1 and PC2 to ISP.
https://ufile.io/js6lu3nw
https://ufile.io/0ugv425e
Any help is greatly appreciated.
Note: I'm using Packet tracer 8.
5 Replies 5
Hello
Your links to the topology isnt working, also you dont share any PT file to review.
Kind Regards
Paul
My Apologies Paul.
I have updated the links above.
Thank you!
balaji.bandi
Some how not able open the link, do you mind attached to forum the pictures.
BB
Martin L
STP Root should be set on top Switch connected to Router; Usually I would set Root like that especially if you have only 1 router.
Static routes are easy; Trick is to remember that you need static entry for each of networks you want to reach.  example ip route 10.0.0.0 255.0.0.0 Gig0/0 (or next-hop IP address)
ip route x.x.x.x y.y.y.y via interface or next IP hop.
Regards, ML
**Please Rate All Helpful Responses **
