06-10-2022 09:31 AM
Setup is two Nexus, connected to various downstream switches in vpc. Each switch has one connection to each of the Nexus.
No direct connections between the switches.
Network outage which I believe was caused by user connecting a cable from a hub back to another access port on the same switch. Log types from the access switch and Nexus are as below.
Access switch logs
%SW_MATM-4-MACFLAP_NOTIF:
Nexus primary
%EIGRP-3-DUP_ADDR:
%ETH_PORT_CHANNEL-5-PORT_DOWN:
%ETH_PORT_CHANNEL-5-FOP_CHANGED:
%ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN:
%FWM-2-STM_LOOP_DETECT:
Nexus secondary
N3K2 %STP-2-DISPUTE_DETECTED:
%STP-2-DISPUTE_CLEARED:
On the access switches, port fast was enabled but no BPDU guard. I have since applied BPDU guard on all access ports. UDLD is enabled on the fibre links. One of the Nexus is set as root bridge manually.
Not sure if enabling broadcast storm control would help? Would appreciate any other advice and suggestions for best practice.
Thanks in advance
06-10-2022 09:49 AM
- I would wait and possibly test (but there are more implications for that indeed) , if the BPDU guard can do it's job. I once had a similar problem on a network with nexus (vpc) backbone with 4500-office leaf switches where even the bpdu-guard would not kick in. Caused network meltdown when the first bozo did the same as in your case. Later we saw it multiple times, can also happen with bad patching from helpdesk , or user seeing cable on the floor and just plugging it into a network (outlet) e.g. In the end I needed to configure the ports with port security with a maximum of 3 addresses to have a kind of manual bpdu guard (against the loop) - which worked. Storm control from my viewpoint has a lower priority because it can slow down the counter-measuring too. Meaning storm control should be oriented to prevent what it says (when originating from users) , not for loops.
M.
06-11-2022 11:36 AM
Thanks for your reply. Am I right in saying BPDU guard should help in the situations like the one you mentioned "bad patching from helpdesk , or user seeing cable on the floor and just plugging it into a network"? Assuming it works..
06-11-2022 01:41 PM
- Normally , it should work.
M.
06-10-2022 11:58 AM
THIS IS MY OPINION
there are two solution here
USE NON-vPC VLAN for single Link SW connect <<<better solution
or
Peer-Switch in NSK
06-11-2022 11:39 AM
Sorry I am not sure if I understood. I am using "peer-switch" feature in the vpc domain
06-11-2022 03:24 PM
OK, let explain what happened here
with Peer-Switch BOTH NSK send BPDU to the connect access SW,
that perfect for vPC VLAN BECAUSE the access SW "as shown below" is connect via Port channel to both Nexus
meaning that Access SW see ONLY ONE SW "this the core of using vPC is connect to physical SW to build one virtual SW"this is the BPDU send from Both Nexus Peer it show that Root and bridge is same because as I mention above it one virtual SW.
YOUR ISSUE AS I THINK
you connect SW which elect as Root,
Root Bridge by default all Port is Designated FWD, that ok in usually SW but with NSK
NSK always try to keep Peer-link is FWD <<- here the LOOP
access SW send frame ->NSK1->peer-link->NSK2->access SW
the mac address see mac flapping
NSK detect loop storm ""%FWM-2-STM_LOOP_DETECT"".
so your idea by making the BPDU guard I think it solve issue here if NSK send BPDU.
this make the one link to NSK be in err-disable if it detect BPDU from NSK it connect.
please check the access SW
show spanning tree <- are it root for this vlan ??
06-12-2022 08:23 AM
Root for all VLANs is NXS1
The issue specifically with "%FWM-2-STM_LOOP_DETECT" happened at the same time when a bad patching was made in the access layer
06-12-2022 08:50 AM
I know you config nsk1 as root but if connect sw have same priority and low mac it can elect as root,
In access sw
Show spanning tree
Check the root bridge.
06-12-2022 08:59 AM
right, I see what you mean.
On the access switch, the root bridge is shown as NXS1.
06-12-2022 09:20 AM
Accss SW connect to nsk1 direct,
Then by mistake some user connect this SW to NSK2? Is that what happened?
06-12-2022 09:37 AM
Access SW connect to nsk1 & nsk2 direct, port channel.
user mistakenly connected two ports on same access switch together (via a hub)
06-12-2022 09:45 AM - edited 06-12-2022 09:48 AM
Now It clear to me why NSK is detect this LOOP.
happened is as following
NSK send Broadcast/multicast -> Access SW
Access SW forward it via Port 1
BUT Port 1 is by mistake connect to Port 2 in same Access SW
so the broadcast/multicast is return to access SW
the Access SW will forward it to all port expect the Port 2 it receive,
here is LOOP
NSK receive broadcast/multicast it send and detect LOOP.
so portfast not prevent BPDU and stop STP, where when portfast detect BPDU it return to normal port and by default BLK port BUT this done after short period LOOP that not accept from NSK.
this is Why cisco recommend to config BPDU guard with portfast to prevent short period LOOP.
so go ahead config BPDU guard
06-12-2022 09:51 AM
Thanks. I have BPDU guard on all access ports now.
06-12-2022 10:03 AM
You are so so welcome friend.
thanks for sharing your issue and your solution
