06-29-2015 01:37 PM - edited 03-08-2019 12:45 AM
The 3750 series Catalyst switch in our lab has five ports that are up and four of them are in forwarding state with their LED lights blinking green. One port (Gi1/0/7) is blinking amber and is not forwarding although it is up. Output for sh ip int br
Switch#sh ip int br
Vlan1 unassigned YES NVRAM up down
FastEthernet0 unassigned YES NVRAM down down
GigabitEthernet1/0/1 unassigned YES unset up up
GigabitEthernet1/0/2 unassigned YES unset up up
GigabitEthernet1/0/3 unassigned YES unset up up
GigabitEthernet1/0/4 unassigned YES unset up up
GigabitEthernet1/0/5 unassigned YES unset down down
GigabitEthernet1/0/6 unassigned YES unset down down
GigabitEthernet1/0/7 unassigned YES unset up up
GigabitEthernet1/0/8 unassigned YES unset down down
GigabitEthernet1/0/9 unassigned YES unset down down
GigabitEthernet1/0/10 unassigned YES unset down down
GigabitEthernet1/0/11 unassigned YES unset down down
Gi1/0/1, 1/0/2, 1/0/3, and 1/0/4 are up and connected. Gi1/0/7 is up but is not working and has blinking amber light. I read that blinking light most probably means STP blocking. When I checked STP status for vlan 105 (which is for Gi1/0/7), here is what I got:
Switch#show spanning-tree vlan 105
Spanning tree instance(s) for vlan 105 does not exist.
where as for the working vlans, it gives me:
Switch#show spanning-tree vlan 103
VLAN0103
Spanning tree enabled protocol ieee
Root ID Priority 32768
Address xxxx.xxxx.xxxx
Cost 8
Port 3 (GigabitEthernet1/0/3)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32871 (priority 32768 sys-id-ext 103)
Aging Time 300 sec
Doing sh vlan and sh spanning-tree summary gives the output:
Switch#sh vlan
VLAN Name Status Ports
1 default active Gi1/0/18, Gi1/0/19, Gi1/0/20
Gi1/0/21, Gi1/0/22, Gi1/0/23
103 VLAN0103 active Gi1/0/3
119 VLAN0119 active Gi1/0/4
120 VLAN0120 active Gi1/0/1
127 VLAN0127 active Gi1/0/2
1002 fddi-default act/unsup
1003 trcrf-default act/unsup
1004 fddinet-default act/unsup
1005 trbrf-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
103 enet 100103 1500 - - - - - 0 0
119 enet 100119 1500 - - - - - 0 0
120 enet 100120 1500 - - - - - 0 0
127 enet 100127 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 trcrf 101003 4472 1005 3276 - - srb 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trbrf 101005 4472 - - 15 ibm - 0 0
VLAN AREHops STEHops Backup CRF
1003 7 7 off
Remote SPAN VLANs
Primary Secondary Type Ports
Switch#sh spanning-tree summary
Switch is in pvst mode
Root bridge for: none
EtherChannel misconfig guard is enabled
Extended system ID is enabled
Portfast Default is disabled
PortFast BPDU Guard Default is disabled
Portfast BPDU Filter Default is disabled
Loopguard Default is disabled
UplinkFast is disabled
BackboneFast is disabled
Configured Pathcost method used is short
Name Blocking Listening Learning Forwarding STP Active
VLAN0103 0 0 0 2 2
VLAN0119 0 0 0 2 2
VLAN0120 0 0 0 2 2
VLAN0127 0 0 0 2 2
4 vlans 0 0 0 8 8
Switch#
As it can be seen only the vlans that are connected to the network are the ones being shown here. My question is how do I get the vlan 105 to be in the Forwarding state? I tried
Switch(config)#spanning-tree vlan 105
Switch(config)#end
but that didn't fix the issue. Any help would be appreciated.
Thank you.
Solved! Go to Solution.
06-29-2015 01:45 PM
According to the show vlan output, VLAN 105 is not created. Thus, no STP instance can be started for it.
Simply create the VLAN 105 - this should hopefully solve the issue.
Best regards,
Peter
06-29-2015 01:45 PM
Best regards,
Peter
06-29-2015 03:39 PM
Hi Peter,
Creating the Vlan worked. Although the Vlans were being shown in the config, when I re created the Vlan, it came up.
Thank you so much.
Best,
Sadaf.
02-18-2020 09:32 AM
I am facing a problem in 7k Nexus..... New created vlan 4 is not taking part of spanning tree as showing spanning tree instance does not exist for the vlan...... In show vlan it's exist and port also trunk..... Need assistance if I am doing something wrong
08-16-2024 12:01 PM
I am seeing this same issue on a switch but the vlans are there...
Switch#sh spanning-tree vlan 21
Spanning tree instance(s) for vlan 21 does not exist.
Switch#sh vlan br
21 PRTG_VMHOSTS_10.X.X.X/29 active
08-16-2024 01:44 PM
Hello @ehayric1320 ,
how many VLANs are defined in the VLAN database ?
what model of switch is this device ?
There are some low end switches that have a limited number of concurrent STP instances that can run on them like 64 or 128.
use
show spanning-tree summary t
o check how many VLANs have an STP instance and compare it with show vlan output .
you are likely using PVST+ or Rapid PVST
Hope to help
Giuseppe
08-16-2024 02:02 PM
Make new post it better
MHM
08-17-2024 02:48 PM
So I think the issue may be that the VLANs are being pruned (blocked with 'trunk allowed' statements).
It's the only thing that makes sense. This is Rapid-PVST on a 6500 switch.
