Spanning tree instance(s) for vlan x does not exist.
alsayed
Hello!
6509 sup-720 ios version :s72033_rp-IPSERVICESK9-M.
1)does the spanning tree enable on this chassis by default?
2)i configured spanning-tree vlan 1,7 root primary.i issue the command DS# sh spanning-tree vlan 1
Spanning tree instance(s) for vlan 1 does not exist.
DS# sh spanning-tree vlan 7
Spanning tree instance(s) for vlan 7 does not exist.
where the problem?
many 10xs
6 Replies 6
Jon Marshall
Ali
Do a "sh vlan" and post the output.
Also, if you do a "sh spanning-tree summary" is there any output at all ?
Jon
Hello jon!
BTW My l3 interfaces administratively down.and these vlan 1,7 exists in the vlan data base
DS#sh spanning-tree summary
Switch is in pvst mode
Root bridge for: none
EtherChannel misconfig guard is enabled
Extended system ID is disabled
Portfast Default is disabled
PortFast BPDU Guard Default is disabled
Portfast BPDU Filter Default is disabled
Loopguard Default is disabled
UplinkFast is disabled
BackboneFast is disabled
Pathcost method used is short
Name Blocking Listening Learning Forwarding STP Active
Total 0 0 0 0 0
Hi Ali
Doesn't matter about the L3 interfaces as this is layer 2 we are concerned about. Can you post the output of
1) sh vlan
Then pick one of the vlans and do a
"sh spanning-tree vlan "number you have picked"
2) Post output of "sh run" of switch
Jon
jon
also my L2 Interface are administratively down
Ali
You need to have at least one interface up in the vlan for the spanning-tree algorithm to run.
If you have a trunk link that is up then this would do it but if you don't have any trunk links up then you need to bring up a port in the vlan for spanning-tree to start running.
Jon
ok jon;10xs for ur support
Ali
