spanning tree load balance question
mahesh18
Level 6
Level 6
hi all,
i have question here for spanning tree load balance  which was in Switching exam
switch A config
interface fas0/10
spanning tree vlan 1-5 port priority 10
switchport mode trunk
interface fas0/12
spanning tree vlan 6-10 port priority 10
question is how vlan traffic will flow  between switch A  and B
Switch A  has two trunk ports to switch B  which  are fa0/10  and fa0/12.
i know default port priority is 128 and  lower is better.
many thanks
mahesh
Hello Mahesh,
often test answers are not direct and require some effort
direct answers:
LANs 1-10 are configured to load share between fa0/10 and fa0/12.
traffic of Vlan 6-10 goes on fas0/12 link
traffc of  Vlan 1-5 goes on  fas0/10 link
if I tell that fas0/10 is a backup for vlans 6-10 is equivalent to say:
the vlans for which the priority is lowered to 10 will use the link if SwitchA is the root bridge or nearest to the root bridge for all Vlans 1-10
>> so as per you note we can say that port fa0/10 will pass all the vlan traffic right ??
no, fas0/10 would be used for all Vlans only with default configuration that is what I meant in my previous post and I'm sorry if it wasn't clear
Hope to help
Giuseppe
Giuseppe Larosa
Hello Mahesh,
the starting point is always the root bridge
With PVST+ or Rapid PVST a different STP instance is running for each Vlan.
Let's suppose that Switch A is the root bridge for all Vlans of interest of that is nearest to the root bridge
When Switch B has to decide for each Vlan what will be the root port it examines the received BPDUs on both fas0/10 and fas0/12.
the cost of the root bridge is the same so this is a tie
the bridge id of the BPDU sender is the same so thi is a tie
the lowest priority is preferred so port fas0/12 is preferred for those Vlans where priority is set to 10 as you noted.
Notice also that if SwitchB were the root bridge or were better connected to the root bridge these settings on Switch A ports are not effective.
another way to achieve this is to change spanning tree cost on the ports of Switch B:
the cost of the port is added to the path cost on the received BPDU
so you can make STP load sharing per Vlan either by:
changing STP priority per vlan on the upstream switch ports
OR
by changing STP cost per vlan on the downstream switch ports
to be noted with no settings all Vlans will be in forwarding mode only on link fa0/10 - fas0/10, for the lowest port index of fas0/10 in comparison to fas0/12.
Hope to help
Giuseppe
Hi  Giuseppe,
thanks for reply
as per correct answer  it says
. VLANs 6-10 will use fa0/10 as a backup only.
. VLANs 1-10 are configured to load share between fa0/10 and fa0/12.
we know that it is tied on por priority.so lower port number wins and it is fa0/10
but answer says it will use vlan 6 - 10   as backup only?
thanks
mahesh
Hello Mahesh,
direct answers:
Hope to help
Giuseppe
Hi Giuseppe,
Many thanks for wonderfull explanation
regards
mahesh
