Line 0 CTY showing Noise/Overruns
smcline06
I am a novice when it comes with Cisco and am currently learning for CCNA and have a question hopefully someone can answer. My home lab consists of 3 switches and 3 routers. Switches are 2950 series and Routers are 2650.
I have just setup an AS2511RJ so I can remote into this equipment via com port. When I perform a show line command I get this on all my equipment (please also note i have not configured the AS2511, just plugged all the ports in via rollover RJ45 cable.)
Cisco2950-1#sh line
   Tty Typ     Tx/Rx    A Modem  Roty AccO AccI   Uses   Noise  Overruns   Int
*    0 CTY              -    -      -    -    -      0     165     0/116547   -
*    1 VTY              -    -      -    -    -      7       0     0/0       -
     2 VTY              -    -      -    -    -      0       0     0/0       -
     3 VTY              -    -      -    -    -      0       0     0/0       -
     4 VTY              -    -      -    -    -      0       0     0/0       -
     5 VTY              -    -      -    -    -      0       0     0/0       -
     6 VTY              -    -      -    -    -      0       0     0/0       -
     7 VTY              -    -      -    -    -      0       0     0/0       -
     8 VTY              -    -      -    -    -      0       0     0/0       -
     9 VTY              -    -      -    -    -      0       0     0/0       -
    10 VTY              -    -      -    -    -      0       0     0/0       -
    11 VTY              -    -      -    -    -      0       0     0/0       -
    12 VTY              -    -      -    -    -      0       0     0/0       -
    13 VTY              -    -      -    -    -      0       0     0/0       -
    14 VTY              -    -      -    -    -      0       0     0/0       -
    15 VTY              -    -      -    -    -      0       0     0/0       -
    16 VTY              -    -      -    -    -      0       0     0/0       -
What I would like to know is Overruns and noise on the com port. What is this caused by (the Access Server?) and is this somthing serious?
Reza Sharifi
This is usually not a major issue.  Try clearing the line a couple of times and that should go away
use:
clear line console 0
Reza
