Spanning tree problem
cthca2
oct 19 01:21:37.326 GMT-3: %SPANTREE-5-TOPOTRAP: Topology Change Trap for vlan 40
Oct 19 01:21:37.326 GMT-3: %SPANTREE-5-ROOTCHANGE: Root Changed for vlan 40: New Root Port is GigabitEthernet1/0/21. New Root Mac Address is f09e.63cd.f580
Oct 19 01:21:39.294 GMT-3: %SPANTREE-5-ROOTCHANGE: Root Changed for vlan 40: New Root Port is GigabitEthernet1/0/17. New Root Mac Address is f09e.63f6.1780
Oct 19 01:21:39.297 GMT-3: %SPANTREE-5-TOPOTRAP: Topology Change Trap for vlan 40
Oct 19 16:04:28.476 GMT-3: %SYS-5-CONFIG_I: Configured from console by hcamargo on vty0 (192.168.31.175)
Oct 20 01:19:46.450 GMT-3: %SPANTREE-5-TOPOTRAP: Topology Change Trap for vlan 40
Oct 20 01:19:46.450 GMT-3: %SPANTREE-5-ROOTCHANGE: Root Changed for vlan 40: New Root Port is GigabitEthernet1/0/26. New Root Mac Address is 00da.5543.7400
Oct 20 01:19:47.673 GMT-3: %SPANTREE-5-TOPOTRAP: Topology Change Trap for vlan 40
Oct 20 01:19:47.673 GMT-3: %SPANTREE-5-ROOTCHANGE: Root Changed for vlan 40: New Root Port is GigabitEthernet1/0/17. New Root Mac Address is f09e.63f6.1780
Oct 20 01:22:27.643 GMT-3: %SPANTREE-5-TOPOTRAP: Topology Change Trap for vlan 40
This problem is happening every day ate same time. I am trying to do the Tshoot to resolve the cause of this issue. Someone can help please?
8 Replies 8
Every day at same time.
I this time did any SW add to your network or any link active?
Did you check cpu in old stp root SW in this time?
cthca2
CPU is fine in both switches.
But what I see here is that one of this root port is a router that is connected to the office.
Gi1/0/21            Desg FWD 4         128.21   P2p  - switch
Gi1/0/26            Desg FWD 4         128.26   P2p   - link
This router have l2vpn.
So root know is HQ office not in your network.
Check l2vpn
cthca2
No.  The root is g1 1/0/17 that is other switch.
But all day at the same time (1 am ) there is the event bellow but the root continue to be 1/0/17
Gi1/0/17 Root FWD 19 128.17 P2p Peer(STP)
In simple words
Root change if
1- the SW recieve better bpdu from other SW
2- the SW not receive any bpdu from router
Since it temporally then I think SW not recieve bpdu' and why that
1- cpu
2- link utilize
So check these two when it happened again.
cthca2
thanks
When you suggest to check CPU, which specific process I need to check?
CPU utilization for five seconds: 23%/0%; one minute: 24%; five minutes: 24%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 436 7766 56 0.00% 0.00% 0.00% 0 Chunk Manager
2 239491 33562419 7 0.00% 0.00% 0.00% 0 Load Meter
3 157 60645 2 0.00% 0.00% 0.00% 0 hulc_entropy_thr
4 1196 1445010 0 0.00% 0.00% 0.00% 0 DHCPD Timer
5 0 1 0 0.00% 0.00% 0.00% 0 Retransmission o
6 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Dispatc
7 409292985 36778211 11128 0.00% 0.27% 0.20% 0 Check heaps
8 28239 32733 862 0.00% 0.00% 0.00% 0 Pool Manager
9 0 1 0 0.00% 0.00% 0.00% 0 DiscardQ Backgro
10 0 2 0 0.00% 0.00% 0.00% 0 Timers
11 861 91226 9 0.00% 0.00% 0.00% 0 WATCH_AFS
12 665798 670827037 0 0.00% 0.00% 0.00% 0 HUSB Console
13 0 1 0 0.00% 0.00% 0.00% 0 License Client N
14 28582 2793998 10 0.00% 0.00% 0.00% 0 IPC Dynamic Cach
15 0 1 0 0.00% 0.00% 0.00% 0 Image License br
16 82248918 2793951 29438 0.00% 0.02% 0.00% 0 Licensing Auto U
17 222479438 532049172 418 0.17% 0.17% 0.14% 0 ARP Input
18 333744 174762247 1 0.00% 0.00% 0.00% 0 ARP Background
19 0 8 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT
20 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager
21 17 77 220 0.00% 0.00% 0.00% 0 Entity MIB API
22 0 1 0 0.00% 0.00% 0.00% 0 IFS Agent Manage
Show processes cpu sorted 5sec
Share this
cthca2
CPU utilization for five seconds: 25%/0%; one minute: 24%; five minutes: 24%
161 1910435158 4190661454 0 7.51% 7.47% 7.51% 0 Hulc LED Process
7 409310979 36779827 11128 1.14% 0.29% 0.20% 0 Check heaps
219 840176483 3760959675 0 0.29% 0.35% 0.46% 0 Spanning Tree
130 686154734 167819263 4088 0.29% 0.30% 0.29% 0 hpm counter proc
17 222490801 532078785 418 0.24% 0.16% 0.12% 0 ARP Input
354 204055321 802357033 254 0.17% 0.12% 0.15% 0 IP SNMP
193 64311213 101075711 636 0.12% 0.03% 0.00% 0 CDP Protocol
172 264516088 33493878 7897 0.12% 0.12% 0.12% 0 HQM Stack Proces
92 59839487 3569192368 0 0.12% 0.03% 0.00% 0 RedEarth Tx Mana
182 197798115 55939755 3535 0.12% 0.09% 0.11% 0 Power RPS Proces
356 298299739 407570156 731 0.05% 0.11% 0.11% 0 SNMP ENGINE
173 66711089 66987918 995 0.05% 0.02% 0.05% 0 HRPC qos request
206 113615918 524497946 216 0.05% 0.10% 0.11% 0 IP Input
I will try to run this command the same time that have the event (1 am)
Also is a good idea to enable spanning-tree loging to get more specifics logs?
thanks
