Speed duplex command not availabe
suraheel-81
Community Member
Dear
I have 1 cisco 4507 switch with line cards WS-X4606-X2-E, WS-X4448-GB-SFP, WSX4548-GB-RJ45 and super visor WS-X45-Sup6E. I have IOS 12.2(50)SG3 .
Speed auto and duplex auto is only available for the ports WSX4548-GB-RJ45.
whats is the reason behind this, i need to configure both speed and duplex as auto for other ports except RJ45, like X2 and SFPs.
thanks.
8 Replies 8
Mahesh Gohil
Level 11
Level 11
Many optical ports do not support speed/duplex setting but other way is to use below commans
negotiation auto --> parameter fixed by negotiating with connected device
no negotiation auto--> parameter fixed as per port capability
if you want to configure speed/duplex auto use negotiation auto and also make sure other end is configured that way.
Mahesh
Dear mahesh
thanks you for the reply, but unfortunatly this command is also not available
CAT4507-DC-A(config-if)#negotiation auto
% Invalid input detected at '^' marker.
my IOS is enterprise services.
Please try with "speed nonegotiate" command
mahesh
dear
i already test this command, i have read from the ios guide that if this command is use with no, then speed and duplex is set to auto but it did'nt happened.
do i need to upgrade my IOS or there is some thing other problem, because these parameters are basics and is always available for every interface.
yes,
I am using same switch with IOS 12.2(44)SG1 and  these commands are supported.(speed nonegotiate)
this is the reason i advise you to use this command
regards
mahesh
I am already using upgraded version of IOS 12.2(50)SG3,
Does speed negotiation is turned off in a interface by default.
Or should we manually stop negotiation
Leo Laohoo
The reason why you can change the duplex and/or speed for the WSX4548-GB-RJ45 because it's rated for multi-speed:  10, 100 or 1000 BaseTx.
You cannot change the speed and duplex of the rest because they are rated for one and only speed:  Either 1Gb or 10Gb.
WS-X4448-GB-SFP  - means it will negotiate only in 1Gb
WS-X4606-X2-E - means that it will only negotiate in 10Gb.
You can't even use 100-Megabit Ethernet SFP Modules or 100BASE-FX SFP because it's not supported on the  X4448.
Cisco 100-Megabit Ethernet SFP Modules Compatibility Matrix
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL632702.html#wp62767
