Speed/Duplex Mismatch issue
Zeeeee
Hi All,
This is my setup:
Scenario 1:
Port1/48 of 3750 - Speed 100/Duplex Full
Port1/48 of 6509 - Speed auto/Duplex auto
Link is up.
Scenario 2:
Port1/48 of 3750 - Speed auto/Duplex auto
Port1/48 of 6509 - Speed 100/Duplex Full
Link is up.
Scenario 3:
Link is up.
Scenario 4:
Link is down.
I wanted to set it to 100/duplex for both switches but the link fails to be up. Did i miss anything?
Thank you,
Aizat
19 Replies 19
Mark Malone
Is there anything in place between the 3750 and 6509 in scenario 4 , like hub unmanaged switch , riverbed etc  or is it a direct link between the 2 switches ?
Hi Mark,
It is a direct link with nothing in between.
chrihussey
Are they gigabit or 100mb interfaces?
Hi Chrihussey,
3750 is 100mb while 6509 is 1gb.
So if you configure both hard coded as 100/Full maybe you could try a cross over cable. You would need that if they were both native 100mbs.
both those switches should be new enough to support auto mdix for straight through cables would have thought unless it turned off
If its not mdix is the cause what does the show interface g1/48 capabilities show when the interface is hardcoded
Hi Mark,
Am i right to say that i do not think it is a mdix issue as the link is up with auto/auto to 100/full?
Yes true actually id still make sure its on , if its it up its up whether auto or hardcoded , mdix job is only to convert if required its doesn't base itself on speed settings as far as I know , what does the capabilities show when its configured , is it stating its set right
#sh int g1/4/1 capabilities
GigabitEthernet1/4/1
  Model:                 WS-X6748-SFP
  Type:                  1000BaseSX
  Speed:                 1000
  Duplex:                full
  Trunk encap. type:     802.1Q
Hi Mark,
I am out now. Will show you the output in 2hr time.
Hi did you get any further with this
Hi Mark,
Sorry I didnt realize you message. But as suggested, i set it as auto/auto.
Do let me know if you still want me to show the output of the properties as you mentioned above.
ah no that's grand if its working auto/auto best to leave it as it is the recommended way , I was just interested to see why it wasn't working at hardset if you were still trying to set it that way
Hi Mark,
Thank you for assisting!
