Speed nonegotiate disappear on TenGigabitEthernet
Hi All
I cannot bring up TenGigabitEthernet link to HUAWEI and thenI would like to tried to disable speed negotiation. But I can't see this command under TenGigabitEthernet interface but I can see on GigabitEthernet. So anybody can explain me why this command disappear or Cisco use the new command or feature for this one.
Information
     - Router 7606
     - Version 12.2(33)SRD2a
Pichet
Yudong Wu
Level 7
Level 7
You can not change speed on 10gig interface since it only runs in 10gig.
Hi Yudong Wu
Thanks for reply and I don't want to change speed on ten gig but I just need to disable link-negotiation. I would like to know what is default behavior on ten gig for link-negotiation (disable or enable). And if it possible please tell me why the command disappear.
Pichet
Link negotiation feature is not enabled because the 10Gig link will negotiate to 10Gig, full duplex.
