Split DNS
wynneit
Level 4
Level 4
Hi guys I hope some of you may be able to assist me here.
Probably a simple question?
I have 2 vlans 192.168.1.0 and 10.0.2.0. The 10.0.2.0 vlan is the DMZ with a web server hostting for a few freinds. Everything works just fine the server hosts multiple sites and they resolve from external DNS by host name. The client is not running their own DNS server just a setup for web hosting. However I cannot get it to resolve urls hosted on the webserver from the 192 vlan? I know its a DNS issue, or at least I am pretty sure but am I better setting up DNS on one of the web servers or can I use split DNS?
I tried setting up split dns but found little documentation.
Help appreciated config below.
Current configuration : 4099 bytes
version 12.4
no service pad
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
enable password 7 ccccccccccccccccccc
no aaa new-model
dot11 ssid HOME
authentication open
authentication key-management ffgg
guest-mode
wpa-psk ascii 7 fffffffffffffffffff
no ip dhcp use vrf connected
no ip dhcp conflict logging
ip dhcp excluded-address 192.168.1.254
ip dhcp excluded-address 10.0.2.254
ip dhcp pool DHCP_POOL_1
network 192.168.1.0 255.255.255.0
default-router 192.168.1.254
dns-server 94.192.119.254
ip dhcp pool VLAN_2
network 10.0.2.0 255.255.255.0
default-router 10.0.2.254
dns-server 208.67.222.222 208.67.220.220
ip cef
no ipv6 cef
archive
log config
hidekeys
bridge irb
interface ATM0
mac-address xxxx.xxxx.xxxx
no ip address
ip virtual-reassembly
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description **** OUTSIDE ****
ip address 11x.22x.33x.44x 255.255.252.0
ip nat outside
atm route-bridged ip
pvc 0/101
no oam-pvc manage
encapsulation aal5snap
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
switchport access vlan 2
interface FastEthernet3
interface Dot11Radio0
no ip address
encryption mode ciphers tkip
ssid HOME
speed basic-12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface Vlan2
ip address 10.0.2.254 255.255.255.0
ip nat inside
interface BVI1
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 123.123.123.1
ip http server
no ip http secure-server
ip nat inside source list 102 interface ATM0.1 overload
ip nat inside source list 103 interface ATM0.1 overload
ip nat inside source static tcp 10.0.2.1 11x.22x.33x.44x 80 extendable
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
access-list 102 permit ip 10.0.2.0 0.0.0.255 any
dialer-list 1 protocol ip permit
control-plane
bridge 1 protocol ieee
bridge 1 route ip
sdoremus33
Level 7
Level 7
One question is the web server ip address 10.0.2.1 ? Thanks
yes sorry web server is 10.0.2.1
Sorry man I am stuck on this one too, and I am curious as to see what the solution is. Thanks
