split / shaping bandwidth between different branch offices
VegaNenar
Community Member
I searched the forum for similar thread but I could not find one that would give me
the answers I was looking for , so I apologize if t wasn't able to find it .
I have a 100Mbps connection to Internet. The ISP's router has a Gigabit interface. This router cannot be configurated.
I must divide the band among 20 different branch offices but rather than giving each 5Mbs, I would give each 5Mbps guaranteed and 10Mbps peak
I thought I could put a new router ( Can you recommend the model? ) Between the ISP router and the central switch (a Catalyst 3750) that connects the offices and do on this policing and shaping.
I thought of using a Two-Rate policer , classifying according to IP's classes of branch offices . And use something like
class-map police
match access-group 101
policy-map policy1
police cir 5000000 bc 78125 pir 10000000 be 312500
conform-action set-dscp-transmit af41
exceed-action set-dscp-transmit af13
violate-action drop
for policy1... to policy20 with the same configuration except for the ACL (which has to match on IP )
and then apply it to my router on INPUT either on the ISP side that on switch side.
and than apply on both OUTPUT side a policy like that
policy-map anti-congestion
class class-default
bandwidth 100000
random-detect dscp-based
random-detect dscp 14 5 100
random-detect dscp 34 4095 4096 1
what do you think ? Which model of router should I use ?
Thanks in advance
Joseph W. Doherty
To confirm, your hub/HQ has logically 100 Mbps, duplex, and physically gig?
What do your branches have for bandwidth?
Will you traffic be using tunnels?
For 100 Mbps, Cisco recommends a 3925.
  • Hi Jospeth
Yes.
They are not remote sites. The Office are in the same building. They are connected with gigabit ethernet . For each floor there are switches and on each floor there are several independent offices . But the connection to the internet is one,
