srr-queue Bandwidth limit
rayamitchell
Community Member
I am configuring a limit for the bandwidth (up and down) of a client.
I have configured the following on their port:
bandwidth 10240
speed 10
duplex full
srr-queue bandwidth limit 20
I realize there are more robust methods of doing this using class maps, policers, etc., but I am wondering if the above configuration will work and if it has any drawbacks versus using the more complex methods.
Thanks!
Julio Carvajal
Hello Raya,
As you said you are rate-limiting the traffic but not with the granularity that you might need.
If you do not need it and just want to rate traffic as all then you should be good.
In this case you will be rating the interface on a 20 % of the Interface bandwith.
For more information about Core and Security Networking follow my website at http://laguiadelnetworking.com
Any question contact me at [email protected]
Cheers,
Julio Carvajal Segura
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
The bandwidth limit command has some advantages, as it effectively shapes all the port traffic.
The bandwidth limit command only applies to egress, ingress will be allowed at full port speed.
The bandwidth limit command is somewhat inexact (it actually works in increments of six if I recall correctly).
