ssh allow in switch 9300
Leftz
Level 9
Level 9
Folks,
Command "management-interface FastEthernet 2/0 allow ssh" can not been used at switch 9300. do we have similar command with this one? thanks
Mark Elsen
 - Have a look at this document for configuring basic ssh setup in IOS-XE : https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_usr_ssh/configuration/xe-17/sec-usr-ssh-xe-17-book/sec-secure-shell-v2.html , for allowing and or protecting vty lines or terminals check the IOS-XE example from https://freenetworktutorials.com/ssh-configuration-examples-in-cisco-iosios-xenx-osios-xr-and-juniperjunos/
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
are the management interface config with vrf-mgmt ?
