SSH CORE CONNECTION
afathi1992
Frequent Visitor
Frequent Visitor
I CANNOT ACCESS MY CORE SWITCH FROM MY PC BUT I CAN ACCESS IT FROM ANY OTHER SWITCH SSH.
when you access via PC did SW ask username or not ?
what is IP you use in PC is it in same subnet of mgmt VLAN of SW and are you connect PC in port config with mgmt VLAN ?
mostly it issue of GW of SW
MHM
Richard Burts
The OP does not provide any detail to help us understand what the issue might be. So here are some questions which may help us understand better what is the problem:
- can the PC ping the switch address?
- when the PC attempts SSH access is there any prompt from switch?
- does the switch restrict SSH access? Typically that would be with access-class applied on vty.
Rick
Hello
Most probably due to mgt plane policing or acl filtering on the vty lines.
core switch
sh management-interface
sh run | sec line
sh access-lists
Kind Regards
Paul
