SSH from 3650 to Nexus 6K
George-Sl
When I SSH from 3650 to 6K it doesn't prompt for username, instead it goes straight into password,
and I haven't set any enable passwords on my nexus, I don't even know if that is the case but how do you set enable password on nexus 6K,
and one last question, Is Firepower capable of doing a ssh(From Firepower to other devices)?
Thanks a lot
Cristian Matei
    You may first need to enable the feature "feature privilege", before being allowed to configure the secret password, via "enable secret".
   As for FTD being a SSH client, this is not supported; haven't tested the latest releases for this specific feature, but it hasn't been there, the same way as it hasn't been there in ASA, for the same reasons.
Cristian Matei.
5 Replies 5
Reza Sharifi
Nexus OS does not have enable access like the IOS.
Cristian Matei
Cristian Matei.
I forgot to add that I can ssh to the 6K from desktop and it asks for username and password and it works, but when I SSH from 3650 it prompts only for the password, and when I put the password obviously It won't accept it.
so I just set that enable secret, the thing is before I even set that enable secret when I was doing a ssh from 3650 it was still asking for password, and after I set the secret password, I still can't login.
this is a bug, 3650 ssh client is not uptodate enough to do the job?
ok I got it, this must be a cipher issue, although it's not saying it, but it is.
