SSH from cisco C9500-24Y4C with desired source interface / IP?
Pawel.Lipko
Hi!
Short question: how to SSH from cisco C9500-24Y4C to directly connected switch defining my source IP or interface. Telnet seems have tht option, but SSH not
Longer story:
I'm using cisco C9500-24Y4C with soft Version 17.3.1r[FC2]
Recently I created new VRF and made contact subnet to one of HP switches I have connected to that Catalyst.
Config is simple as that:
Catalyst:
interface Vlan516
vrf forwarding SomeVRF
ip address 172.28.4.57 255.255.255.248
HP:
interface Vlan-interface516
ip binding vpn-instance SomeVRF
ip address 172.28.4.58 255.255.255.248
Trying to SSH does not work:
CatalystSW#ssh -vrf SomeVRF 172.28.4.58
% Connection timed out; remote host not responding
But Catalyst can ping it:
CatalystSW#ping vrf SomeVRF 172.28.4.58
Sending 5, 100-byte ICMP Echos to 172.28.4.58, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/2 ms
HP switch is able to SSH to itself using newly added IP address:
<HP_SW>ssh2 172.28.4.58 vpn-instance SomeVRF
Username: admin
Press CTRL+C to abort.
Connecting to 172.28.4.58 port 22.
The server is not authenticated. Continue? [Y/N]:Y
Do you want to save the server public key? [Y/N]:Y
admin@172.28.4.58's password:
Enter a character ~ and a dot to abort.
<HP_SW>exit
Connection to 172.28.4.58 closed.
But Catalyst seems to use some different interface than directly connected one
If I try to SSH to HP switch - it fails:
CatalystSW#ssh ?
-c Select encryption algorithm
-l Log in using this user name
-m Select HMAC algorithm
-o Specify options
-p Connect to this port
-v Specify SSH Protocol Version
-vrf Specify vrf name
WORD IP address or hostname of a remote system
CatalystSW#ssh -vrf SomeVRF 172.28.4.58 ?
WORD Command string
<cr> <cr>
If I try to telnet to see if port is listening - it fails
CatalystSW#telnet 172.28.4.58 22 /vrf SomeVRF
Trying 172.28.4.58, 22 ...
% Destination unreachable; gateway or host down
But if I define source interface for telnet - it reaches SSH service
CatalystSW#telnet 172.28.4.58 22 /vrf SomeVRF /source-interface vlan 516
Trying 172.28.4.58, 22 ... Open
SSH-2.0-Comware-7.1.070
The question is: how to ssh from cisco C9500-24Y4C defining source IP or interface?
Only telnet allows that function?
SSH -o is not helping
CatalystSW#ssh -o ?
numberofpasswordprompts Specify number of password prompts
2 Accepted Solutions
balaji.bandi
how about configuring :
ip ssh source-interface XXXX
hope you have vty line to allow outgoing connection.
BB
config need to done on config mode.
config t
BB
5 Replies 5
balaji.bandi
BB
Thanks for answer, but this one doesn't have such option
Catalyst_SW#ip ssh?
% Unrecognized command
Catalyst_SW#ip ssh ?
Catalyst_SW#ip ?
dhcp DHCP related commands
sla SLA
config t
BB
you are genius!
Thanks!
It works!
as @balaji.bandi  suggest
