Nexus switch port is flapping
there are 4 nexus switches 5596, and problem is only on Switch00-01.
a port 2/8 towards firewall is flapping every few hours, causing disconnects.
This is a sync failure state port which forces the firewalls to do a failover,
when it fails and cause interrupts because of hardware limitation on their side the port is failing and causing the above situation.
found no errors on the firewall /connected environment.
IOS version 7.1(3)
no input/output errors on the switch port, only link failure messages.
replaced cables to that port and moved it to another switch, which seems to have solved a bit the problems.
how may we find any indications on faults or if this situation can happen in the future.
2022 Jul 1 08:07:58 Switch00-01 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet2/8 is down (Link failure)
2022 Jul 1 08:08:01 Switch00-01 %ETHPORT-5-SPEED: Interface Ethernet2/8, operational speed changed to 1 Gbps
2022 Jul 1 08:08:01 Switch00-01 %ETHPORT-5-IF_DUPLEX: Interface Ethernet2/8, operational duplex mode changed to Full
2022 Jul 1 08:08:01 Switch00-01 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet2/8, operational Receive Flow Control state changed to off
2022 Jul 1 08:08:01 Switch00-01 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet2/8, operational Transmit Flow Control state changed to off
2022 Jul 1 08:08:01 Switch00-01 %ETHPORT-5-IF_UP: Interface Ethernet2/8 is up in mode access
2022 Jul 1 08:23:49 Switch00-01 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet2/8 is down (Link failure)
2022 Jul 1 08:23:53 Switch00-01 %ETHPORT-5-SPEED: Interface Ethernet2/8, operational speed changed to 1 Gbps
2022 Jul 1 08:23:53 Switch00-01 %ETHPORT-5-IF_DUPLEX: Interface Ethernet2/8, operational duplex mode changed to Full
2022 Jul 1 08:23:53 Switch00-01 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet2/8, operational Receive Flow Control state changed to off
2022 Jul 1 08:23:53 Switch00-01 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet2/8, operational Transmit Flow Control state changed to off
2022 Jul 1 08:23:53 Switch00-01 %ETHPORT-5-IF_UP: Interface Ethernet2/8 is up in mode access
balaji.bandi
is this ever worked ? this was seen only recently (and was working stable before)
what is other side connected device ( i mean what FW ?)
First check Physical cable
Move the config to different port and check
post interface config and interface status:
show run interface Ethernet2/8
show interface Ethernet2/8
BB
Jitendra Kumar
have you manually configured interface speed and duplex?? if it auto negotiates then change it to manual both devices
Please share the output show interface command this port
Jitendra
I think you need to change port or cable it L1 issue.
