05-15-2012 11:58 AM - edited 03-07-2019 06:43 AM
I have a 3560 switch running: version 12.2(55)SE3 image: c3560e-universalk9-mz.122-55.SE3.
I can ssh into the switch from a remote pc just fine using usernames and passwords.
I want to use keys so that the ssh does not prompt me for login info.
under my switch when I a in config t mode, I do not see the commands for: ip ssh pubkey-chain
I only have the following options under ip ssh
All the documation i see has procedures for entering ip ssh pubkey-chain ...... but I don't get that option.
I thought the K9 image supported this? What have I not turned on for the options to appear?
As I said, I can ssh into the box fine, but when I follow a procedure for enabling ssh keys I don't get the commands they say should be available.
05-16-2012 06:31 AM
Some documentation says to perform the following to setup ssh for rsa keys:
Perform this task to configure the Cisco IOS SSH client to perform RSA-based server authentication.
1.
enable
2.
configure terminal
3.
hostname name
4.
ip domain-name name
5.
crypto key generate rsa
6.
ip ssh pubkey-chain
7.
server server-name
8.
key-string
9.
exit
10.
key-hash key-type key-name
11.
end
12.
configure terminal
13.
ip ssh stricthostkeycheck
Step 6 is where i cannot complete the command because it does not exists. I do have a k9 image so its not that issue.
It turns out the i can get the same mode by entering:
(config)#crypto key pubkey-chain rsa
not sure if this is a documentation error or a difference between iso versions 15 and 12.
10-08-2014 09:48 AM
It's a difference between IOS versions. Support for login with SSH RSA keys begins in IOS 15.
04-09-2019 12:23 AM
I am having the same issue. The IOS software installed is a C1841-advipservicesk9-mz, Version 12.4(11)T4.
The Secure Shell Configuration Guide Cisco IOS Release 12.4 (https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_usr_ssh/configuration/12-4t/sec-usr-ssh-12-4t-book.pdf) mention the command.
Does anyone know why and how to solve the issue?
Thank you for your help,
Bernard_
