SSH not working for some devices, PING works for all - 3560 switch
Filip Knezevic
I have a strange problem which I already encountered before.
There is a 3560 switch, L2 device with VLANs. SSH was working properly. I setup the new MGMT VLAN and it was still working. Yesterday I noticed I cannot connect to SSH from a laptop on another network, but I can ping it. Read all the threads were no ip classless was recommended and no ip routing as well, didn't help.
So, SSHB is version 2. There are no ACLs blocking ssh. Telnet is also enabled and not working.
I can connect from a directly connected switch.
From a laptop on a different subnet I can ping it, but SSH is not prompting. Telnet is not prompting.
This means:
IP connectivity is good, all devices can ping the switch.
SSH is properly configured, key is generated and SSH works from directly connected network.
PING is working from a PC that cannot SSH - so we know the IP connectivity and the gateway are good.
What I tried:
no ip routing
no ip route with ip default gateway
ip classless no ip classless
I noticed it was setup as login local on vty so I tried with AAA new model and also didn't work.
Relevant switch config
line vty 0 4
logging synchronous
length 0
transport input telnet ssh
line vty 5 15
ntp clock-period 36029542
ntp server 172.20.200.110
ntp server 172.20.200.121
end
version 12.2
no service pad
service timestamps debug uptime
service timestamps log datetime
service sequence-numbers
hostname ARO-MTL-4
boot-start-marker
boot-end-marker
enable secret 5 $1$Oek6$R.PwLMORbgHuxDLtDLnEH0
username filip privilege 15 secret 5 $1$Owme$WdVrNCWx1T0NQUVUqGzTT.
aaa new-model
aaa session-id common
clock timezone GMT -5
clock summer-time EDT recurring
system mtu routing 1500
vtp domain ARO2
vtp mode transparent
ip domain-name ARO
spanning-tree mode mst
spanning-tree mst configuration
name ALL-VLANs
spanning-tree mst 0 priority 8192
spanning-tree vlan 1-200 priority 8192
vlan internal allocation policy ascending
vlan 81
name MGMT-VLAN
vlan 90
name PHONE
vlan 91
name MGMT
vlan 120
name DATA
lldp run
ip ssh version 2
ip default-gateway 172.20.11.129
ip classless
ip http server
ip http secure-server
no cdp run
snmp-server community checkmk RO
banner login ^C Wel^C
line con 0
logging synchronous
line vty 0 4
logging synchronous
length 0
line vty 5 15
end
2 Accepted Solutions
Then it connect issue.
Make sure the pc have ip in same subnet of mgmt vlan of SW
Connect it to port assign with same vlan
Check above
MHM
I fixed it. The issue might be in multiple VLAN interfaces on the switch and some asymmetrical routing. I removed VLANs 120 and 90 and I left only the 172.20.11.134 VLAN. Now it works immediately
thanks
26 Replies 26
There is no IP for any vlan?
MHM
there is IP of course
Vlan81 172.20.11.134/26
Vlan90 10.120.1.11/24
Vlan120 172.20.120.4/24
Did you generate RSA key for SSH?
You need domain and generate key
https://www.cisco.com/c/en/us/support/docs/security-vpn/secure-shell-ssh/4145-ssh.html
MHM
As you mentioned Layer 2 switch and have configured Default gateway.
From what IP address you trying to SSH to device ?
Can you post below output :
show ip interface brief
show ssh
show ip ssh
On other hand you have telnet also enable using from PC are you able to telnet to switch ?
BB
Filip Knezevic
Yes, I have all that. Also, note that even telnet doesn't work.
Also note that SSH is working from other switches to this SAME switch.
no aaa new-model
vtp domain ARO2
ip domain-name ARO
No aaa new model
And there is no password and login local or login under vty
Sure that make vty stop work.
MHM
You are not answering what was asked in the past post
Also note that SSH is working from other switches to this SAME switch. - this works since it is in the same subnet ?
So if the device have IP address,  and multiple vlan interface in it, move from default gateway to ip routing (enable routing and static route - ip route x.x.x.x y.y.y.y
that should fix the issue high level
BB
BB sorry mate, will answer everything. Thanks for taking an interest into my post.
I tried everything you suggested already.
I'm trying to SSH from a PC on 172.20.120.40. That same PC CAN PING the switch. So the default gateway/ip route is good.
I tried to do it with ip routing and ip route and without ip routing with ip default gateway, same issue.
what you saw in vty was because of aa new model. When you turn that on, login local is gone.
Again, I tried both with aaa new model and with login local.
Now I disabled aaa new model and it's just login local.
ARO-MTL-4#sh run | b vty
line vty 0 4
logging synchronous
login local
length 0
line vty 5 15
login local
ntp clock-period 36029541
end
Login local is best if you dont need to controle command and exec.
Go with login local.
MHM
Yeah, I did. Still the same. I was trying aaa newmodel because I didn't know what else to try lol
Don't worry friend
It happened alot
Good luck
Have a nice weekend
MHM
When you use aaa new model
All vty use
Login auth defualt
But you dont config
Aaa auth login command
That why the access failed and login local disappear
So when you enable aaa new model
You need to use
Aaa auth login defualt local
Command
And I prefer login local than use aaa.
MHM
I also only use login local and aaa only for radius implementations.
I don't think this issue is related to that, however. I think the switch config is correct and that's why I'm confused by the issue.
So is this resolved - still having issue ?
you mentioned coming from PC 172.20.120.40   Vlan120 172.20.120.4/24
it bit confusing here you mentioned that from other switches you able to login - if this is true ?
BB
