ssh problem from router to switch
hamzashahid
hi this is hamza shahid
i'm trying to make ssh session between router and switch , i have setup ssh in switch and trying to take remote through ssh to router , the problem is when ever i try this shows an error which says connection refused by host
what did i config i have mentioned all configuration and also wording for clearance
i firstly make vlan 2 in VTP server switch then i went to client switch and entered this command which is switchport access vlan 2 in ether-channel config ports which was also using trunking mode
 then i went to router to make sub interface for inter vlan i assign ip there statically and added that network to ospf routing protocol now i can  ping 192.168.10.2 but i am not able to make ssh session to this ip as i have mentioned error above  kindly review that for more clearification kindly review my all running configuration
this is my router configuration::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::
Current configuration : 2980 bytes
version 15.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
service password-encryption
hostname central#router
enable password 7 08264542294B5445
ip dhcp pool VLAN10
network 10.0.0.0 255.255.255.0
default-router 10.0.0.1
ip dhcp pool VLAN11
network 10.0.1.0 255.255.255.0
default-router 10.0.1.1
ip dhcp pool VLAN12
network 10.0.2.0 255.255.255.0
default-router 10.0.2.1
ip dhcp pool VLAN14servers
network 10.0.3.0 255.255.255.248
default-router 10.0.3.1
ip dhcp pool VLAN-APs
network 10.1.0.0 255.255.0.0
default-router 10.1.0.1
ip dhcp pool VLAN#13
network 10.0.4.0 255.255.255.0
default-router 10.0.4.1
ip dhcp pool WAN
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
ip dhcp pool VLAN-15
network 10.0.5.0 255.255.255.0
default-router 10.0.5.1
no ip cef
no ipv6 cef
username gil password 7 08264542294B5445
ip domain-name gil.com.pk
spanning-tree mode pvst
interface GigabitEthernet0/0/0
no ip address
duplex full
speed 1000
interface GigabitEthernet0/0/0.2
encapsulation dot1Q 2
no ip address
interface GigabitEthernet0/0/0.10
encapsulation dot1Q 10
ip address 10.0.0.1 255.255.255.0
interface GigabitEthernet0/0/0.11
encapsulation dot1Q 11
ip address 10.0.1.1 255.255.255.0
interface GigabitEthernet0/0/0.12
encapsulation dot1Q 12
ip address 10.0.2.1 255.255.255.0
interface GigabitEthernet0/0/0.13
encapsulation dot1Q 13
ip address 10.0.4.1 255.255.255.0
interface GigabitEthernet0/0/0.14
encapsulation dot1Q 14
ip address 10.0.3.1 255.255.255.248
interface GigabitEthernet0/0/0.15
encapsulation dot1Q 15
ip address 10.0.5.1 255.255.255.0
interface GigabitEthernet0/0/0.16
encapsulation dot1Q 16
ip address 10.1.0.1 255.255.0.0
ip access-group 100 in
interface GigabitEthernet0/0/1
ip address 192.168.10.1 255.255.255.0
ip access-group 101 out
duplex full
speed 100
interface Vlan1
no ip address
shutdown
router ospf 2
log-adjacency-changes
network 10.0.0.0 0.0.0.255 area 2
network 10.0.1.0 0.0.0.255 area 2
network 10.0.2.0 0.0.0.255 area 2
network 10.0.3.0 0.0.0.255 area 2
network 10.0.4.0 0.0.0.255 area 2
network 10.1.0.0 0.0.255.255 area 2
network 10.0.5.0 0.0.0.255 area 2
network 192.168.10.0 0.0.0.7 area 2
ip classless
ip flow-export version 9
access-list 100 permit ip 10.1.0.0 0.0.255.255 192.168.10.0 0.0.0.255
access-list 100 deny ip 10.1.0.0 0.0.255.255 any
access-list 100 permit ip any any
access-list 101 permit ip 10.0.5.0 0.0.0.255 host 192.168.10.2
access-list 101 deny ip 10.0.5.0 0.0.0.255 any
access-list 101 permit ip any any
line con 0
login local
line aux 0
login local
line vty 0 4
login local
transport input ssh
line vty 5 14
login local
transport input ssh
line vty 15
login local
transport input ssh
end
this is my VTP server switch config::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::
Current configuration : 2361 bytes
version 12.2
hostname central#switch
interface Port-channel1
interface Port-channel2
interface Port-channel4
interface FastEthernet0/1
switchport access vlan 14
switchport mode access
duplex full
speed 100
interface FastEthernet0/2
duplex full
speed 100
interface FastEthernet0/3
duplex full
speed 100
interface FastEthernet0/4
duplex full
speed 100
interface FastEthernet0/5
duplex full
speed 100
interface FastEthernet0/6
switchport access vlan 16
duplex full
speed 100
interface FastEthernet0/7
duplex full
speed 100
interface FastEthernet0/8
duplex full
speed 100
interface FastEthernet0/9
duplex full
speed 100
interface FastEthernet0/10
duplex full
speed 100
interface FastEthernet0/11
duplex full
speed 100
interface FastEthernet0/12
duplex full
speed 100
interface FastEthernet0/13
duplex full
speed 100
interface FastEthernet0/14
duplex full
speed 100
interface FastEthernet0/15
duplex full
speed 100
channel-group 4 mode desirable
interface FastEthernet0/16
duplex full
speed 100
interface FastEthernet0/17
duplex full
speed 100
channel-group 1 mode desirable
interface FastEthernet0/18
duplex full
speed 100
interface FastEthernet0/19
duplex full
speed 100
interface FastEthernet0/20
duplex full
speed 100
interface FastEthernet0/21
duplex full
speed 100
channel-group 2 mode desirable
interface FastEthernet0/22
duplex full
speed 100
interface FastEthernet0/23
duplex full
speed 100
interface FastEthernet0/24
duplex full
speed 100
interface GigabitEthernet0/1
switchport mode trunk
duplex full
speed 1000
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
and (VTP client switch)  finally config or that switch in which i want to make ssh session::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::
version 12.2
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 100
duplex full
speed 1000
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
hope u understand that all
Best Regards:
HAMZA SHAHID
it is solved now thanks for guidance what did i do is here u can see
i went to central router and then made gig0/0/0.20 and added vlan 20 with ip adddress of 192.168.20.1 255.255.255.0
and then went to vtp server switch made vlan 20 there and also made int vlan 20 with ip adddress of 192.168.20.2 255.255.255.0 in reomte switch and configure all ssh configurations there which worked now
u may close this thread now as solved thread
Best Regards
HAMZA SHAHID
Mark Malone
have you turned on ssh in the device your trying to access ?
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh source-interface x
ip ssh version 2
ip domain-name ineedssh.com
line vty 0 4
transport input ssh
then also enable crypto and you must have a K9 image on the device for SSH
(config)#crypto key generate rsa
hit return type 2048 and hit return again it wil generate keys
The run show ip ssh to see if the keys are there and ssh is fully enabled
#sh ip ssh
SSH Enabled - version 2.0
thanku for reply
yes its enabled and now it is saying connection refused by host although it is able to ping 192.168.10.2 which is at interface vlan 2 in remote switch through any network
this command is not showing in packet tracer which is ip ssh source-interface
where am i making mistake in configurations kindly help me to figure it out.
Best Regards:
HAMZA SHAHID
ok so your trying to ssh out this interface below yes the far end of 192.168.10.1 is that correct from the hostname central#router ? is ssh enabled to on the router your trying to ssh too 192.168.10.2 router ?
remove the access-list as a test and retry but first confirm the router your trying to ssh to has it enabled
duplex full
speed 100
Best Regards
HAMZA SHAHID
